Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Heater is on firing up- everything seems ok but there is nogas-goes thru the cycle with igniter glow orange but does not ignite- there doesnt seem to have any gas present to ignite weathermaker 8000
    Problem Solver:
  • 17 Answers
The igniter has to have proper omhos to open gas valve.
recommend replacing igniter. be careful not to touch new igniter with bare hands. oils in the skin of your hands will cause the igniter to get too hot and burn out quick
Posted on Dec 10, 2009
LG Trom gas dryer dlg5988B got under water 10 inch. The motor is running, just the gas heater does not burn. Computer is working right. Any idea?
Take top off, start drying cycle and see if you can see an orange glow on bottom right front of unit-the Glow plug igniter. If it glows, then you have a different issue. If no orange glow, replace igniter.
Nov 26, 2017 | LG Dryers
There is no heat on any of the cycles.
Check Igniter, Igniter Sensor (Senses Igniter is glowing) & gas valve Coils. Remove Front or rear access panel to observe/access these items. Set heated dry cycle & start dryer while observing Igniter, should start to glow bright orange for several seconds, sensor should send millivolt power to valve coils that will CLICK opening valve producing blue flame for heat. If Igniter doesn't glow within a minute, its bad, If it glows & nothing else happens it's either Sensor or Coils are bad, check the coils by using Ohm meter across plug ends of coils, if bad you will get no reading on meter, coil is open & no good, or take both Sensor & Coils to repair shop and have them tested. All 3 are accessable thru access panel opening.
Feb 14, 2011 | Dryers
Sometimes when my gas plaque infrared gas space heater comes on a ball of loud flame bursts out in front of one of the plaques instead of lighting up the plaque. What causes this only occasionally? How can...
It sounds like a delayed ignition- and YES!-- that could be dangerous if something flammable was nearby, and no one was around to make sure the fire did not start something int he room on fire!
Trouble shooting delayed ignition:
Does this heater use a glowing ignitor to ight?
Or a standing pilot?
Or a spark?
I suspect that whatever is supposed to light the gas burner, is not in the path of the first gas release, (when the gas valve Opens) and so it takes a bit for the gas to build up, and finally get around to the source of ignition-- and then WHOOSH!!-- all that extra gas ignites!
Can you see the ignitor as it goes thru its first firing cycle-- what do you notice about the ignitor?
Something to consider:
What prevents it from filing the room with gas, before it ignites!
Sounds mighty dangerous to me!
Let us know what happens, and what you find-
Mack B
Jan 23, 2011 | Procom 10K BTU, Vent Free, 2 Plaque...
Goodman furnace, inducer blower comes on, but surface igniter does not turn red, then kind of goes thru a cycle then igniter gets red burners light and then go out for no reason. Blower motor comes on @...
In the burner compartment opposite of the ignitor is the flame sensor. seems to be dirty. one screw holds it in. Remove and clean with a wire brush.
Nov 21, 2009 | Goodman GMS90703BXA Heater
Where is the pilot light on Goodman mod. PGB042100-1 REV A
This model has electronic ignition. You will need to remove the top panel, tape the door switch closed, have an assistant raise the thermostat above room temperature while you look thru the small window for an orange glow. If you do not see the glow, chances are you have a bad igniter.
Oct 18, 2009 | Goodman GMS90703BXA Heater
Ignitor won't ignite after working for 2-5 min
Your fuel supply is OK?
If the igniter comes on and you have fuel, there is no problem ... for some reason you dont have fuel, seems to me.
Did you check the gas valve(s). There nay be several.
If you have gas and the valves are on ... you have an electric (gas relay valve) problem.
Sep 27, 2009 | Dryers
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 01, 2009 | Dryers
Reddy r200b keroseen heater will not ignite
CAD flame sensor is bad, also check your air inlet line for the fuel mix, could be cracked.
Jan 20, 2009 | Desa International Reddy Heater R200BT...
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
136 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
