Question about KitchenAid Dishwashers
KitchenAid Superba Whisper Ultima Quiet: Inside the door ia a blue knob with numbers ranging from 1 thru 6. What is this feature?
5 Suggested Answers
SOURCE: Child lock blinking on a Kitchenaid ultima diswasher.
Try holding the E.S. button down for 30 seconds. Does not work, you need an Electronic control assembly which can be ordered online from Repair clinic .com for $146 for your model plus shipping. This is apparently a common problem with Kitchenaid dishwashers. Just repaired one the other day. Tried everything, but as soon as the new Electronic control assembly was installed, everything was Okay. This is an easy repair for anyone who is handy at all. Please shut off power to the dishwasher by switching the breaker off or removing the fuse.
Posted on Feb 20, 2010
  • 3230 Answers
SOURCE: Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
Posted on Mar 02, 2010
tbreeze47
  • 3083 Answers
SOURCE: Kitchenaid Superba Whisper Quiet Ultima:
Not familiar with that model, but one time I found a baby sock jamming the water outlet in a dishwasher, so check to make sure there's no foreign object blocking any exits. Other than that, I suspect it will need to be serviced, or at least taken apart for further inspection.
Posted on Mar 13, 2010
  • 10865 Answers
SOURCE: My KitchenAid Superba (whisper quiet
Hello. If the unit is over ten years old, I advise against repair. But if you do wish to consider repair, here are the things to look at
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Mar 18, 2010
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
KitchenAid Whisper Quiet Plus dishwasher Location of serial number
Usually, the sticker is located on the inside edge of the door on either the left or right side--you have to open the door to see it.
Aug 19, 2015 | KitchenAid Dishwashers
I have a kitchenaide Superba Monterey 21, whisper quiet dishwasher that will not drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 05, 2011 | KitchenAid Dishwashers
Kitchenaid Superba Whisper Quiet Ultima: It won't drain. I returned from a trip to find a puddle of water in the basin/reservoir, which usually drains during a normal wash/dry cycle. Now it'll shoot out...
Mar 13, 2010 | KitchenAid Dishwashers
Good Luck!!
Thanks
Mar 02, 2010 | KitchenAid Dishwashers
Feb 04, 2010 | KitchenAid KUDR25 Dishwasher
KitchenAid Superba
http://www.kitchenaid.com/custserv/service.jsp
Enter your model number and it will give a listing of the manuals available to you.
Feb 11, 2008 | KitchenAid KESC307 Electric Kitchen Range
Dishwashers Logo
725 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
