Question about Hitachi 61HDX98B 61" Rear Projection Television
Tv works good picture is good and clear sound is good but im only getting blue and red colors??? is that the board? or the green bulb?
That is what happened with are tv. My husband took the tv apart and started messing with everything and got the tv to line up better. he just turned the nobs and messed with the coloring.
Posted on Sep 24, 2010
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
My tv color is very red and orange but all 3 color bulbs are working it seems... the actual picture only comes through the red and green... help!!!
go to tvrepairkits.com and order the kit that replaces the fluid in the blue and green bulbs, will clear up your color issues no problem :) i just fixed mine, now it looks great.
May 10, 2010 | Philips 55PP9352 55" Projection Television
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
Jan 23, 2010 | Toshiba 36A41 36" TV
Panasonic pt43lc14 no red color. picture is good. cannot get anything to look normal color after trying to adjust color/tint/picture etc. Have alot of blues and yellow, and brown. seems like no red.
It appears that your light engine is broken, I have the same problem. Have you recently changed the bulb with a non-panasonic part bought on the internet. I did this and think thats what caused the problem. I believe the new bulb burn at a higher temp thus causing damage to the Light engine filters
Jan 04, 2010 | Panasonic PT-43LC14 43" Rear Projection...
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
Toshiba 57HX81: Green works but Blue and Red seem to be out.
Do you still have reds? Is the image still clear though discolored? If so you ought to replace the blue bulb which has most likely failed. The part no for the 57HX81 model blue CRT bulb is TOSHIBA     23008753.
Jun 11, 2009 | Toshiba 57HX81 57" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Phillips 50p8341 Projection tv no picture
Looks like the blue crt is bad and may have killed the main power board that has the high voltage supply.
A new crt is almost $400 and my distributer shows the power supply as no longer available, but may be able to get it somewhere else. Plus you need the service manual to realign and converge everything (hope you didn't mess this up too bad). Really need to find a good rear projection tech to do all this, but may not be worth it.
Jan 02, 2008 | Philips 50P8341 50" Rear Projection...
Loss of color - all green
yes! the problem is in the CRT board the RGB colors! you have lost of blue and red! thats why your unit is green! and only green is worked the blue and red is not work! maybe you have lost contact of them! resolder all CRT board to comeback the normal picture!
Sep 28, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Open Questions:
Hitachi 61HDX98B 61" Rear Projection Television Logo
77 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
