Question about Encore PrintMaster 17 Silver Full Version for PC
Printmaster 17 won't open projects created in printmaster 11.
I now have Printmaster silver 17. I previously had printmaster gold and printmaster platinum 11. I had saved many projects from the old programs. None of those projects will open in the new printmaster. Why? This is very frustrating! I continued with Printmaster specifically so I could access my old projects. When I try to open the old programs it says''Printmaster failed to open project'' and the computer locks up.
    Habit-Forming:
    New Friend:
  • 64 Answers
Www.manualsonline.com
Posted on Sep 27, 2017
    Sergeant:
    Habit-Forming:
  • 118 Answers
Printmaster 1 was for windows 98, ver 17 is for XP. it depends where your saved projects are. if they are on CD media then that is READ ONLY and they must first be transferred to a C:\ drive and their ATTRIBUTES for each and every file/folder of the project need to have the Read Only attribute removed. you can do that via CMD.exe eg if your project was inside a folder called c:\myprojects\????? then you would type in ATTRIB/S c:\myprojects\*.* -R then your projects might be valid as they could be UPDATED/Altered by the new version but thats just a guess.
SOURCE: cant save to pdf in printmaster gold 17
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
Posted on Feb 01, 2009
viff27
  • 6 Answers
SOURCE: uninstalling printmaster silver 12
u can't remove ur print master? i had encounterd this prob before
so try to install again ur print master to overwrite all files. coz u unistall it improper thats why u can.t remove it..
try to install again and after that u can now remove it into add/remove progam thx for posting!!
Posted on Jun 27, 2009
  • 1752 Answers
SOURCE: I GET AN ERROR1305 IN THE MIDDLE OF THE INSTALL OF
Your CD is dirty or damaged: http://support.microsoft.com/kb/248263
Posted on Oct 22, 2009
  • 187 Answers
SOURCE: Just got Windows 7 and trying to install
Windows 7 has a compatibility wizard that you can use to help install it. Go to start, control panel, and then type in troubleshooter in the search box. Under programs, click "run programs for other versions of windows." Follow those instructions. If you need to browse to the setup file on the disc, do so. If that does not work, you can go to Broderbund's web site. They have a compatibility update for Gold 17 on their website. Unfortunately it is for Vista, but it still might help you with the compatibility issue
encore .
Posted on Nov 18, 2009
  • 10406 Answers
SOURCE: Is there an instruction manual for Printmaster Platinum 2.0
Is there any PDF documents on the CD-ROM?
Is there a "help" function within the software?
Posted on Apr 10, 2010
I cannot install PrintMaster Platinum 2011 on my Windows 7 computer. Is there a way to do it? It says it is compatible with windows 7.
Administrator privileges are required to properly install the program on Windows® XP, Windows Vista®, Windows® 7 and Mac OS X for PrintMaster Platinum 2011 .
Using mouse, right click on the "setup" and Run as "Administrator"
Hope it helps.
Apr 28, 2011 | Encore PrintMaster 17 Gold for PC
I had Printmaster 10 installed on my computer, but recently had to reload, I saved my invoice files to a disc, but they will not open up unless I reinstall Printmaster 10. I have Windows XP, and the disc...
I suspect that when you re-installed 10 it corrupted in some way and did not install properly. If you are using the same computer as before and the same software disc as before, then unless you had an update, which changed printmaster 10, it should be the same as before.
The only updates to Printmaster 10, would have been around a few years after it came out. There are no software updates for any software that still works only on XP as the system is now redundant.
Try re-installing Printmaster 10.
May 19, 2017 | Broderbund Print Master Silver 16.0 for PC
Why don't they make a CreataCard ''Gold'' that works using VISTA?? I missing this great program
Create a Card is a discontinued product.
Encore has new PrintMaster® Gold Version 18 ($19.99) and PrintMaster® Platinum Version 18 ($39.99) programs, both with Vista support :
http://www.encoreusa.com/products.aspx?SearchTerm=create+a+card
Aug 16, 2009 | Computers & Internet
Cnnot open PrintMaster 17
Printmaster Platinum downloaded and installed reasonably well on my Gateway 6mb RAM 500MG HDD running Vista Home Premium.  The 26.5MB patch seemed to install okay.  In trying  to open the app I got the folloiwing:  "Error opening HKLM with ALL ACCESS - setting up registry"  I uninstalled--completely-- and the reinstall worked the same way with the same Error Message. The install followed the instructions that came with the patch via msconfig.  I can get the app to run with a lot of time-consuming effort using Task Manager.  Once opened it seems to work fine. It might be a good idea to offer a definition for HKLM, which is to say IHABT.  Oh, yeah, I HAD A ***** OF A TIME.
Presumably this is a registry entry or dll.  Please shed some light on this.  I have used this program for years and have a  host of saved projects.  PrintMaster Gold worked much better but I paid a bunch of money for Platinum (knowing full well  it was an older edition).
Help
Apr 06, 2009 | Broderbund PrintMaster® Platinum 17 Full...
Cant save to pdf in printmaster gold 17
3-click PRINTER
Jan 28, 2009 | Broderbund PrintMaster Platinum 16
I have Printmaster 10 and 17. On 10, I can print to the edges of the labels and others things, on 17 I can't. I know that I reconfigured 10 to do this, but it was years ago and I can't remember the step...
Custom Paper Wizard PrintMaster® 17 Gold and Platinum include a Custom Paper Wizard that allows you to add new or unsupported paper stock to PrintMaster® for printing labels, stickers, envelopes, half-fold greeting cards, note cards, business cards and postcards. The remainder of this note describes how to use the Custom Paper Wizard. Follow the procedure below to add a new or unsupported paper stock to PrintMaster® 17 Gold or Platinum using the Custom Paper Wizard.
NOTE: The options that appear in the Custom Paper Wizard vary depending on the project type for which you are creating new paper stock.
  1. In the PrintMaster® Design Workspace, click Tools from the menu bar, select Custom Paper Wizard and click New Custom Paper. The Custom Paper Wizard window will open.
  2. In the Select Stock Type: list box, select the appropriate project type (Label, Sticker, Business Card, Envelope, 1/2-Fold Greeting Card, Note Card or Postcard) and click Next.
  3. If creating a Label or Sticker paper stock, select the label type. An example of the selected label type will appear on the right.
  4. Click Next.
  5. In the screen that appears, select the similar stock type and enter the paper height, width and margins (if instructed to do so).
    NOTE: The Example box at the bottom of the Custom Paper Wizard window will explain what information is needed for the selected field (e.g., Paper Width, Left Margin, etc.) with both text and a diagram. The Example box on the left side of the Custom Paper Wizard window will show an example of the new paper stock as the fields are completed.
  6. Depending on the paper stock, the "Contains mid-page perforation" box may be active. If the paper stock that is added has a mid-page perforation, click once in the empty box to check it.
  7. Enter a Name for the new paper stock in the Name of stock: field and click Next. This name will identify the added stock type and will appear when creating a new project (e.g., Label, 1/2-Fold Greeting Card, etc.).
    NOTE: If adding a new paper stock for an Envelope project type, click Finish. A message will appear indicating that the new stock has been added. Click OK. The new envelope paper stock can be used when creating a new Envelope project.
  8. The next screen or screens that show will depend on the project type for which the new paper stock is added. Enter the needed information and click Finish. A message will appear stating that the new paper stock has been added.
  9. Click OK.
  10. To access the new paper stock, create a new project that uses the stock type (Label, 1/2-Fold Greeting Card, etc.) and select the name of the new stock entered in Step 7 (above) from the available stock list.
NOTE: If the paper stock that is added does not display in the list, click or go to Custom Paper Stock Does Not Display (Technical Note ID: 43399) for additional information.
Using the Custom Paper Wizard Tutorial
Consult the "Using the Custom Paper Wizard" tutorial in the Help Center of PrintMaster® 17 for additional information. The tutorial can be accessed in the manner shown below.
  1. Launch PrintMaster® 17.
  2. Click Help on the menu bar and select Help Center.
  3. Click the View or Print Tutorial icon (light bulb).
  4. Under Choose a Category, click Program Tutorials.
  5. Under Choose a Topic, click Using the Custom Paper Wizard
Oct 13, 2008 | Computers & Internet
Encore PrintMaster 17 Silver Full Version for PC  Logo
179 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
