Question about Kenmore Refrigerators
Relay switch, everything is defrosting - Kenmore Refrigerators
  • tnubian541 Dec 10, 2009
    He is checking it now, and I am cringing, this is worse than his attempting to fix the car, he states that there is something running, but he does not know what it is, I knew I should of went to school for situations such as this!
    Tara
  • Mark Egan May 11, 2010
    Is the compressor running? Usually located bottom, back, behind a black cover. Round black ball looking thing with 3 tubes going in and coming out. One line should be HOT, the other warm, and the other is just a stub. There is also a fan down there, check that it is running. Do not lose the cardboard shield as it is important to maintain airflow.
    President:
  • 1,214 Answers
If he hears something is running at the bottom back, it's probably the condensor fan. The black round ball like thing with tubes goiung in and out is the compressor. It will probably be either very hot, or very cool. And, it may click about every 10 minutes or so. If it does, you've probably got a bad compressor. Depending on how old the refrigerator, it might be better to get a new refrigerator for Christmas.
Posted on Dec 10, 2009
Testimonial: "This was very helpful, but to attempt to explain that to Mr. I can fix anything, the fridge is 20 years old, and I can't complain about it at all! "
Wiring diagram for 2005 grand marquis for rear defroster
Relay maybe . free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click Body & accessories ,then under subsystem click on rear window defogger . Click the search button then the blue link .Looking at the diagram you will see three fuse's , a relay ,lighting control module , defroster switch . The switch is a input to the lighting control module , the lighting control module will supply a ground to the control side of the rear window defroster relay ,energizing the relay sending B+ power to the defroster grid.
Sep 28, 2017 | Cars & Trucks
Which relay/fuse controls the power windows?
Visual Inspection Chart Mechanical Electrical
  • Door window regulator and motor
  • Door glass top run
  • Door window glass
  • Loose, corroded connectors
  • Circuitry
  • Window control switch
  • Battery junction box (BJB) fuse(s):
    • 1 (60A)
    • 3 (60A)
    • 11 (50A)
  • Smart junction box (SJB) fuse(s):
    • 7 (20A)
    • 27 (10A)
    • 30 (10A)
  • SJB circuit breaker 10 (30A)
  • SJB rear window defrost relay 1
  • Relay center box 1 rear window defrost relay 2
  • Delayed accessory relay
  • Battery saver relay
  • Rear window defrost grid
Apr 23, 2016 | 2005 Ford Taurus
Where is the Power Windows Fuse in a 2005 Ford Taurus?
It is located in the SJB smart junction box , it's a fuse / relay center / microprocessor ! Fuse # F2.10 30 amp . location -behind left side dash panel . Also check the accessory relay . Top relay left side , same location SJB .
  • Door window glass
  • Circuitry
    • 1 (60A)
    • 3 (60A)
    • 11 (50A)
    • 7 (20A)
    • 27 (10A)
    • 30 (10A)
Sep 23, 2015 | 2005 Ford Taurus
HOW DO I WIRE A TOGGLE SWITCH TO REAR DEFROST SWITCH. TOGGLE HAS 3 WIRES DEFROST HAS 6 WIRES?
You should not try to wire the switch to the actual switch harness, instead identity the relay that powers the defrost, because toggle switches are only to switch power on and off to a device.
Nov 25, 2014 | Cars & Trucks
Everything has defrosted the lights are still on. and there is no no noise coming from the back of it now.
If this is a self defrosting unit, the defrost timer may be stuck in the defrost cycle. Or perhaps the cold control went bad, or even the compressor or starting relay burned out.
Jan 06, 2010 | Whirlpool Freezers
Small chest freezer, running but not freezing, cold inside, everything defrosted
the freezer has a defrost timer and relay. if either is bad, it may get stuck in defrost mode(depending on what position the switch failed in). The fan will run constantly if this is the case. You may choose to follow the wiring diagram on the back of the service panel or hire a technician. If you do it yourself, unplug the unit for your safety
Nov 19, 2009 | Freezers
Ge frezzer goes into defrost mode and defrosts EVERYTHING! Ice cubes refreeze solid as one. HELP!
sounds like your defrost termination switch is not cuttin off heater when ice on evap melts.switch is surpose to cut off heater when it reaches a certain temp. replace defrost termination switch
Aug 27, 2009 | Freezers
Ge sidebyside, made in May,'02. It is not keeping things cold on either side. I have a thermometer in the freezer side and it is reading45 degrees. I have cleaned out the back and vacummed out the dust and...
I could be the same thing but there are three components to the defrost system. And this is somthing you can probably do yourself.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a frigidaire freezer ffu21cwaw1 we lost power for 4 hours now the freezer sees to be defrosting. the power light is on and it is set to coldest but everything is defrosting.It is not a frost free...
There probably was a power surge from the power failure which has taken out your control board or the starter relay switch for the compressor.
May 05, 2009 | Frigidaire Freezers
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
rlrguitar
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
