Question about Radio Communications
Motorola spectra i am trying to wire up a motorola spectra mobile radio i know red is power and black is ground than comeing off of the control head you have a green and orange wire are them ground or power.
  • 3 Answers
They are NOT for the speaker. Speaker wire is black "zip cord" with plastic connector coming off of control head connector. The Green and Orange are Ignition sense wires. How they are wired determines the power state of the radio, i.e. if to BATT radio will be on unless shut off, if to IGN radio will power up when ignition turned on.
Posted on Apr 20, 2008
  • 589 Answers
Those should be for the speaker.
Posted on Jan 19, 2008
Green and orange go to igniton
Posted on Apr 16, 2008
Orange and green shuold be powered to a hot to turn on the remote
Posted on Feb 12, 2008
IM TRYING TO WIRE A PIONEER DEH-5 TO MY STOCK WIRES IN MY 1996 VOLKS JETTA. I CHECKED OUT THE WIRING DIAGRAM ON THE JETTA AND SOME OF THE WIRES DID NOT MATCH UP,LIKE FOR INSTANCE THE SWITCHED WIRE ON THE...
Hi, the plain orange wire is the power wire. The constant wire is only for maintaining the station presets--it does not power the unit on. The other orange wires are for speakers. See the full color code below, and let me know if you have any more questions.
1996 Volkswagen Jetta Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/White
Car Radio Switched 12v+ Wire: Orange
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Blue
Car Stereo Amplifier Location: If equipped, each speaker has an individual amplifier located at the speaker.
Left Front Speaker Positive Wire (+): Blue/Black
Left Front Speaker Negative Wire (-): Orange/Black
Right Front Speaker Positive Wire (+): Red/White
Right Front Speaker Negative Wire (-): Orange/White
Left Rear Speaker Positive Wire (+): Red/Light Green
Left Rear Speaker Negative Wire (-): Orange/Black
Right Rear Speaker Positive Wire (+): Blue/Light Green
Right Rear Speaker Negative Wire (-): Orange/Red
May 07, 2011 | Alpine CDM-7874 CD Player
2005 kia spectra blower dont come on for the heater
The 2005 Spectra heating system comprises 4 main components and its associated wiring.
1. Blower Relay- supplies power to the blower motor when the key is in the on position
2. Blower motor- Located in the right side dashboard area near the passengers right foot. ( photo attached)
3. Resistor- located on the ground side of the circuit to control speeds 1 thru 3. Note" High speed bypasses this component.
4. A/C Control Module- This is the control pad in the dashboard with the blower speed controls.
The easiest way to diagnose this circuit is to split the circuit in half to determine if you have a power supply problem, ground control problem or a failed component. From your concern I am going to assume that none of the speeds work. If some of the speeds work let me know which ones and I will revise the diagnosis tree I made for you.
Key state for all tests is Key on/Engine off. Heater on and blower setting between 1 and 4.
Step 1. Verify the 30Amp blower fuse in the underhood fuse box has power and is not "Blown.
Step 2. Locate the blower motor by removing the lower kick panel on the passenger side dashboard and glove box. You will need a Phillips head screwdriver.
Step 3. Disconnect the two pin connector at the blower Connector G-02 in the attached photo. The red and blue wire is the power supply wire to the motor so with the key on/engine off check for power with a test light or volt meter. Spec: Battery Voltage. If good proceed to step 4. If no power proceed to step
Step 3.a.- the blower relay above the blower (connector G-06) and verify you have power leaving the relay. This is the red and blue wire ( Pin 4) I attached a photo of the connector to help locate the correct wire. If you have power at this pin the relay is working and you have an open between the relay and the blower motor. If you do not have power at this pin proceed to step 3.b. Verify that the relay clicks when you disconnect it from the harness and plug it back in. If it "clicks" and you have no power at pin 4 you have a bad relay. If it does not click you will need to check the power supplies to the relay. These are pins 3 (blue wire) and Pin 5 (Red wire). Be careful to check the correct blue wire as the other blue is the ground for the relay. (Pin 1). If you do not have power at either wire you have an open in the harness and further diagnosis will be needed. If you do have power at these wires then check the remaining blue wire for a ground. If you do not have a ground you may have a bad control module. To check this remove the plastic cover around the control head and radio and remove the control head from its mounting but leave plugged in to the harness. Check the white and blue wire in pin 21 of the large connector. It is located 3 pins in from the bottom left of the connector. (See attached photo). If you do not have a ground then you have a bad control module. To verify this you can ground this wire with a test light or fused wire and see if the relay "Clicks". If you do have a ground at this pin then you have an open between the relay and control head.
Step 4. - Ground check- Go to the blower motor connector and check the green and red ground wire (Pin 2) for a ground with the blower switch set to 4. This bypasses the resistor easing diagnosis. If you have a ground then the blower motor is at fault. If you do not have a ground proceed to step 5.
Step 5. Access the control head large connector. Leaving it plugged into the control head check pin 23 (Yellow black wire in the lower left corner of the connector) and verify you have a ground. If you do not have a ground you have a faulty control module. If you do have a ground you have an open between the blower motor and the control head requiring further diagnosis. simplesol907.jpgsimplesol907_0.jpgsimplesol907_1.jpgsimplesol907_2.jpgsimplesol907_3.jpg
Jan 08, 2011 | 2005 Kia Spectra
Im installing a JVC KD - A315 radio in a 2003 alero, when i took out old radio all the wires were cut and turned into speaker wire running all over the place the factory amp is in the back i went ahead...
There may be extra wires you don't need. The basic set of wires on the radio is 4 pairs of colored wires--one black-striped and one plain for each speaker. Yellow is usually accessory power, red is hot, and black is ground. Some additional wires may be one for a power antenna, one for an external amplifyer, and one for facelight (in case it will run on dimmer)
The car should have the following corresponding wires:
Radio 12v--- orange
Radio Ground--- black
Radio Ignition--- yellow
Radio Illumination--- brown
Dimmer--- gray
Power Antenna--- pink (if you have one)
LF Speaker +/- tan - grey
RF Speaker +/- lt green - dk green
LR Speaker +/- brown - yellow
RR Speaker +/- dk. blue- lt. blue
The car or radio could have additional connectors, such as for a subwoofer, CD changer, etc.
Aug 28, 2010 | 2003 Oldsmobile Alero
2006 kia spectra audio wiring diagram
This should help you out. Good Luck.
Radio Ground black - radio harness
Radio Ignition pink + radio harness
Radio Illumination blue/black + radio harness
Factory Amp Turn-on N/A
Power Antenna green/black + radio harness
LF Speaker +/- blue/red - yellow/black +,- radio harness
RF Speaker +/- black - yellow +,- radio harness
LR Speaker +/- brown - white +,- radio harness
RR Speaker +/- green/orange - blue/orange +,- radio harness
Jun 13, 2010 | Kenwood Car Audio & Video
I need to know the wiring color diagram for
Radio 12Vorange Radio Ground black Radio Ignition pink Radio Illumination
blue/black Factory Amp Turn-on orange/black Power Antenna green
Left Front Speaker (+/-) red - blue
Right Front Speaker (+/-) white - brown
Left Rear Speaker (+/-) orange - blue
Right Rear Speaker (+/-) orange - green
Mar 07, 2010 | Mobile Authority Car Audio & Video
Radio harness is cut trying to install new radio need wire diagram
2003 Kia Spectra Car Stereo Wiring Color Codes
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Green
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): Yellow/White
Right Front Speaker Negative Wire (-): Yellow/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Black
Left Rear Speaker Negative Wire (-): Brown/Green
Right Rear Speaker Positive Wire (+): Light Green/Yellow
Right Rear Speaker Negative Wire (-): Ornage/Black
Jan 05, 2010 | 2003 Kia Spectra
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Oct 03, 2009 | Hunter 52" Ceiling Fan With Light And...
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
LOOKING FOR WIRING DIAGRAM FOR STOCK HEADUNIT
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
Apr 04, 2009 | 2003 Honda Accord
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Radio Communications Logo
616 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
