Question about Acer Aspire 3680 Laptop
Battery charger hole will not work on the acer 3680 something is amiss any suggestions
  • Acer Master
  • 32,281 Answers
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Dec 10, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Why is acer 3680 2682 not charging
Because it is an old model (end of service life and not supported anymore) and the battery possibly not holding any charge and needs replacing, i think this works ok on just the charger without battery.
Jun 08, 2014 | Acer ASPIRE 3680-2022 Notebook
My acer aspire 3502 has charger light flashing orange
try taken your battery out and start with out it,see if it still flash,if not then replace battery.
or it could be faulty charger.
May 25, 2014 | Acer Aspire 3680 Laptop
How do u put a acer aspire 3680 back 2 factory reset !!!!!!!!!!!!
Look underneath for a tiny hole and the words reset, if you find it use something preferably not sharp or likely to break ie. an unfolded paper clip poke it gently into the hole and you should be OK. john
Jul 19, 2010 | Acer Aspire 3680 Laptop
The aspire 3680 will not trun on. battery will not charge. even with the charger plug in
plug unit into wall remove battery boot computer. if it boots up you will need to replace your battery
Nov 14, 2009 | Acer Aspire 3680 Laptop
I have an acer aspire 3680 computer, Before the battery wasnt working so i bought a new one. Well now the battery came and i tried to charge it, but its not indicateing that its charging and won't charge...
Taking the fact that you already replaced the battery into consideration, chances are that you have a faulty cord. Looks like you're going to need a new one mate.
Sep 16, 2009 | Acer Aspire 3680 Laptop
I have a acer aspire 3680 that will not charge
The power cube is the problem..lets face it you had a 50/50 chance of getting to the root of the problem..so by replacing the battery that only leaves....
Don't Forget to rate the advice!!
http://www.aa1consulting.com
Jul 27, 2009 | Apevia HQRP Replacement Laptop AC Adapter...
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
