Question about Texas Instruments TI-86 Calculator
How to open (remove) TI-86 Keyboard
The number 1 key sticks to the panel in the up position(when not pressed) on my TI-86. It started about half a year ago. Probably something sticky has got between the button and the front board. At first it was not disturbing me much but now it has got worse. I'm afraid that the key 1 will stop functioning if i don't clean it. I want to remove the front board and clean it.
Http://www.takeitapart.net/archives/ti-83-and-86/
Posted on Jul 21, 2008
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
There are screws on the back. unscrew those carefully and then pull the two sides apart and start cleaning. GOOD LUCK
Posted on Feb 12, 2008
I have a TI-86, whenever i input - it shows Ans- and then it show that is an error. how can i fix it.
The - key is for subtraction, an operation that needs two numbers. If you press - as the first key on a line, the calculator assumes you want to subtract something from the previous answer, Ans.
If you want to enter a negative number, use the (-) key on the bottom row of the keyboard, just to the left of the Enter key.
Apr 05, 2016 | Texas Instruments TI-86 Calculator
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    How to calculate cube root on simple calculator
    That depends on how simple a calculator. I'll give some examples below for calculating the cube root of 8.
    On a TI-86, press 3 2nd [MATH] F5 MORE F4 8 ENTER
    If the calculator has a "^" or "y^x" key, raise 8 to the 1/3 power. Again, on the TI-86, press 8 ^ ( 1 / 3 ) ENTER
    If the calculator has a logarithm key, take the logarithm, divide it by three, then take the antilogarithm. Again, on the TI-86, press 2nd [e^x] ( ln 8 / 3 ) ENTER
    On a slide rule, place the hairline over the number on the K scale and read the cube root on the D scale.
    Jan 10, 2013 | Texas Instruments TI-86 Calculator
    When I type on my keyboard on my computer numbers are popping up instead of letters
    Press the Start key + R.
    type osk in that box and hit enter
    On this keyboard, try toggling numlock scrolllock and capslock a few times.
    Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
    hope this helps
    Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
    or
    Examine your keyboard to ensure your "Number Lock" key is not activated.
    This activation is indicated by the key being lit up.
    If the key is activated, press it to deactivate the lock.
    The number lock key will deactivate an entire segment of your keyboard
    Start, click Run, and type regedit to open the Windows registry editor.
    In the registry, open the below folders.
    HKEY_CURRENT_USER\
    Control Panel\
    Keyboard\
    Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
    0 = Num Lock is turned OFF after the logon.
    1 = Disable Num Lock.
    2 = Numlock is turned ON after the logon.
    hope this helps
    Nov 08, 2012 | Computers & Internet
    Hos do I adjust the screen brightness?
    Press and release the 2nd key and then press the up-arrow to darken or the down-arrow to lighten. Repeat as needed.
    Sep 20, 2012 | Texas Instruments TI-86 Calculator
    Converting negative deg F to deg C produces conversion error
    If your measurement are negative use parentheses such as, (-4) degrees Fahrenheit converted to Celsius should = -20. Where as 4 degrees Fahrenheit equals -15.5 degrees Celsius. the parentheses are not needed if your measurement is positive.
    Dec 20, 2010 | Texas Instruments TI-86 Calculator
    The screen on my TI-86 calculator is black when I turn it on. What do I do?
    You can adjust the contrast on the screen of your TI86 by following the procedure below.
    Adjusting the Contrast
    1 Press and release the yellow [2nd] key.
    2 Press and hold UpArrow or DownArrow (above or below the half-shaded circle).
    ¨ To darken the screen contrast, press and hold UpArrow.
    ¨ To lighten the screen contrast, press and hold DownArrow.
    Hope it helps.
    Nov 04, 2009 | Texas Instruments TI-83 Plus Calculator
    Calculator (TI-86) will not come on.
    Make sure batteries are fresh (unspent)
    Make sure batteries are inserted correctly, respecting the + - diagram.
    To adjust contrast:
    1. Press and release [2nd[ key
    2. Press and hold [UpArrow] key to darken screen or press and hold [DownArrow] to lighten it. Keep it until contrast is to your liking.
    Hope it helps.
    Mar 15, 2009 | Texas Instruments TI-86 Calculator
    TI 86
    Press "2ND" "MATH" "F3" to invoke the Angle menu.
    Enter the number of degrees, press "F3", enter the number of minutes, press "F3", enter the number of seconds, press "F3", then press "ENTER".
    Feb 15, 2008 | Texas Instruments TI-86 Calculator
    Texas Instruments TI-86 Calculator Logo
    1,255 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Stevan Milanovic
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
