Dear Ladies & Gentleman,
I have a vacuum cleaner Rainbow E Series wich stoped working. I verified the lower security shaft that is working perfectly. Dismounted the device and noted that the engine is not clogged. There are two golded kind of engine breaks (opposite one each other) wich I dismounted to verify both string's strengh. They seem a bit weak and the brakes a bit used. Experiencing the engine, I turned it on, with the empty canister in it's place and I noted that, when I make the machine's restore (red button), the engine spins for a bit making some sparkles and it turns off again(that I know is the security system working). Now, my problem is not knowing that, if by having those used "engine brakes" (and I will know their exact function with a mechanic at my work place), is there missing some small pieces that keeps the engine working as it was for this 8 years of life of that wonderfull cleaner (used to many times in my cars too).
Thanks for all the attention and any good help ;-)
Comment by TOUROPT, posted on Jan 20, 2008
Dear Friend,
Thank you for the help, actually I contacted Rainbow's representatives in my country, telling them the problem and asking for a solution. Next Monday I'll call them too. Hope they remember and confirm that of the 10 year engine warranty ;-)
I think what you are talking about are the motor brushes. If they are sparking alot, then they need to be replaced, but also a bad armature will cause this and replacing the carbon brushes won't help. In that case you would have to replace the motor. But I thing the E series has a 10 year warranty on the motor, so you may want to check on that as this motor is very expensive.
Rating Locked! (?) TOUROPT has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Rainbow E series with sparkling engine:
