Question about Powmax 400 Watt ATX Switching Power Supply - ATX ver. 2.03 - ATX 12V ver. 1.1 - AMD and P4 Ready (PSCM450W) Power Supply
I am looking for a replacement PSU for my ASUS P4T-E.
I need one with 20 pin, 4pin, and 6 pin AUX, have looked at a lot of web sites, but have not ben able to find the right PSU. None of them seem to have the 6 pin AUX connector.
  • 407 Answers
Your connector is of two has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Posted on Jan 24, 2008
Turned off, would not come back on the next morning, opened up and cpu heat sink and fan totally clogged with dust. Cleaned all dust out with vac and tooth brush, and then with compress air in a can from...
old old pc, super old. and packed up.
s/w (software?) im sure you ment the physical hardware switch.
not the windows start, shutdown soft switch.
so, that means the mobo cables fell off from the front panel to the switch.
The switch tells the mobo to turn off,
the the mobo, south bridge chip(if it has power) tells the PSU to turn off, and does.
wow a radioshack still open ,id take a photo.... for old times sake.
the PSU new before fail or after? you did not say.
no display tells me , no power.
fans on tells you only 12vdc is ok, not the other 6-8 rail voltages, ever. and regs,/
used PSU or new.
what PSM make and model.
I ask that because there are ATX an ATX2 versions
the old version is missing a key cable on newer PC
the PC with video and OR, cup power aux jacks.
let me look up your mobo now.
carbon dated at year 2006, old but not relic yet,
Athlon 64 X2 ( most are how in the trash)
windows XP the dead OS and now virus magnet.
only 1 express slot, x16,,,
im looking on a mobo now for sale, and same number above
and it does have 4 pin CPU aux power jack,
if not connected, there is no changes, at all of working'
ill assume the xpress slot is empty, no Geforce GFX750 there, LOL.. overloading that slot to... and its aux jack missing too...
if i had the data on your new PSU i could wax smarter...
see red arrow, and 4 pin , 12v aux jack, the PSU connects here.
and the 24 pin on rear side of mobo. both.
Oct 18, 2017 | HP Pavilion a1630n PC Desktop
Can not find PSU for ASUSP$B266 withA2542 3 pin connect. for CH_F
I think you are a bit confused here. Ther MoBo CH_FAN connector is an output for a Chassis Fan and does not need a supply from the PSU. It is dfor use if you wish to connect a fan to the casing to provide extra cooling and for the fan speed to be reported in the bios..
Apr 08, 2010 | ASUS Computers & Internet
Motherboard does not boot
seems to me you have a motherboard issue
Jul 03, 2009 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Where to plug case side fan
Pinout Pin number Wire color Description 1 yellow +12 volts 2 black ground 3 black ground 4 red +5 volts
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
Do I need a 4pin-4pin DV cable or a 4pin - 6p -with Canon MV 850i
The camera has a 4-pin slot. If the slot on your computer has a slot the same size as your camera, it is 4-pin. If it is larger, it is a 6 pin slot.
Dec 31, 2008 | Canon ZR850 Mini DV Digital Camcorder
Inno3d 9800gt is it compatible with asus p5vd2-mx motherboards?
What I beleive is your problem is that a single 4Pin connector doesn't provide enough of the right power connections. I have a 9600GT and like you my PSU doesn't have a 6pin connector. But fortunately for me the manufacturer of my card (BFG) had the Foresight to include the adapter that I need (Which was a Y cable with 2 4pin (Molex) connectors to one 6pin (PCIe) connector.
First thing I'd do is check ALL of your packaging to see if your manufacturer also included such an adapter. It may be hiding (Taped to the inside of the cardboard packaging or stuffed in a bag with papers/warranty info)
Retail boxes usually list the parts included so you can look to see if a "duplex molex to PCIe" is on it.
If this search proves futile, you might check at your local PC hardwarestore (Best buy, Circuit city, or if you have a specialty store like MilwaukeePC here in Milwaukee)
If that is not an option and you have a credit card/Paypal account you can try an online retailer such as NewEGG or CDW jsut add the dot com to their names for their websites.
I hope you find this Usefull
Nov 15, 2008 | ASUS P5VD2-MX SE Motherboard
Asus P4T-M version 1.05 Not Posting?
Hi ed, that 4-Pin ATX_12 connector near the CPU is for powering the CPU. Suggest you change PSU's. Though I'd agree there are some boards that have the 4-Pin connector & it's not used. Those boards usually have a 24 pin main connector & lower voltage CPU's Please check here at Asus web site for P4T-M.
Related FAQ's P4T-M
I'm sure your P4T-M will boot after connecting the ATXPWR, ATX12V. As you noted, it would be nice if you could test the memory. When you get display you can test your memory for free by downloading a mem test program at.
Enjoy the weekend Ed.
Mar 20, 2008 | Computers & Internet
No display
check that your display card is seeted properly and your ram,if you have two ram chips remove the chip in socket no.1 and replace it with the other chip.
Nov 06, 2007 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Powmax 400 Watt ATX Switching Power Supply - ATX ver. 2.03 - ATX 12V ver. 1.1 - AMD and P4 Ready (PSCM450W) Power Supply Logo
183 people viewed this question
Top Powmax Computers & Internet Experts
David Payne
David Payne
Are you a Powmax Computer and Internet Expert? Answer questions, earn points and help others
