Question about Philips Televison & Video
Mod. 42PF5321D will not turn on. red lite blinks 6 times. trying the sw. on side turns green lite, followed by 2 "clicks" then lite goes off. by H. Moravec e-mail: missionspringsapts@gmail.com
  • Philips Master
  • 19,396 Answers
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
In your case six blinks means: Signal Processor (IC 7150) error , a fault had been detected by the main board.
This is a logical fault.
Contact Philips at the phone and ask if there is a fix or a firmware update that can fix the problem.
If the error comes back, the parts must be tested at component level to fix the problem.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Dec 09, 2009
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
My sony trinitron kV ES 34M90 GIVES 6 ERROR BLINK CODES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Sony Televison & Video
I have a Philips 42pf5321d/37 that won't turn on.
send me a email sonny@tvcircuitboards.com and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
Green lite turns on for 2 second and then turns
Please listen and try this:
When the power light comes on and goes off, on the front of the set press BOTH the Menu and Input (Device) buttons at the SAME time and HOLD them both for at least five seconds and then release both.
The power light will blink a two digit error code and will repeat it about 5 times. To get it to repeat you would have to unplug the set and turn it on again etc.
The most common error is 2 blinks, pause, 2 blinks.
Let me know what error code you find and I will direct you as to what it means and what may have to be done.
SD TECH
May 13, 2010 | Mitsubishi WS-55311 55" Rear Projection...
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
6 red blinking lights
6 times blink shows following error in tv...
+5 Volt is not supplied (G Board)
If your are tech person, you can understand it easily.
Need further help, let me know.
Regards,
Sep 12, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Power lite blinks red and will not turn on
Sounds to me like you're experiencing an issue with the power supply in the unit.
Nov 21, 2007 | NEC PX-42VM3A 42 in. EDTV-Ready Plasma...
Sony LCD projection TV - bulb problem
Hi! sweet123,
Please answer this question. Were the 4 bulbs visabley bad; say broken or did they have a milkey look, or broken wire inside? In other words did the bulbs you replaced look as good as a new unused bulb? Please reply.
toprol
Nov 15, 2007 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
