Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Coils in frezer keep frezing up - Kenmore 20.6 cu. ft. Top Freezer Refrigerator
  • Mark Egan May 11, 2010
    You either have a bad defrost heater, defrost temperature sensor, or defrost timer. It depends on the Model of refrigerator. Will need a Model number to confirm what to look for, and where it can be found.
    President:
  • 1,218 Answers
Good day,
The reason for this conditi0on is the defrost system has failed.
It is made up of 3 components,
The main heater, a calrod unit mounted under the evaporator coil, a defrost thermostat, which is a small round disk, mounted on the top of the evaporator.
The third is the timer, either mechanical, or adaptive(electronic) which is mounted in the roof of the fresh food compartment.
The main heater can be tested for continuity with an ohm meter, as can the defrost thermostat. The defrost thermostat must be tested before it reaches 50 degrees since it may open above that and give you a false reading.
The timer, if it's mechanical has a slot in the housing where it's mounted. To test, with a small screw driver, until the machine turns off. Wait 35 minutes. If it turns itself back on, then it is good.
If not, it must be replaced.
To test the adaptive (solid state) timer, the test is different.
There will no slot for advancing it.
With the machine running, unplug it from the wall. Turn the thermostat completely off. Wait in excess of 30 seconds, and then plug the machine back in. It will defrost the coils if it is working.
Caution: this will not work, if the defrost thermostat is bad.
Below is a good explanation with pictures to help you out.
http://www.appliance411.com/faq/howdefrostworks.shtml
Posted on Dec 09, 2009
  • John Hall Dec 09, 2009
    Hello again,
    The hyperlinks tools are not working at the present time.
    Highlight it and paste it in the address bar of your browser.
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
INSIDE OF THE BACK OF FREEZER THE COIL/WIRE BRUSHES AND THAT AREA KEEPS FREZING UP AND FRIDGE RUNS ALL THE TIME
Check the defrost heater at the bottom of the coils. Also check the defrost thermostat clipped onto evap coils
May 01, 2018 | Refrigerators
Keeps frezing up. ice on the coils, not blowing cold air
Try to make general general cleaning of the unit specially the coils.
Aug 10, 2011 | Windchaser PAC8 Air Conditioner
Frezer does not freze evrything defrost
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2011 | Arctic Air Refrigerators
Water leaking into bottom of frezer,water frezing on bottom then leaking onto floor
defrost drain bottom rear of freezer is blocked . Defrost and clean drain tube.Poor water in trough at back under rear panel. If it drains out quickly then it is clear.
Oct 29, 2010 | Frigidaire Kitchen Ranges
Ge model # tff34rvf refrigerator runs then shuts off for a long time. frezer makes ice and frezes items then things thaw agan
run times are to long . caused by dirty cond coil or fans running too slow . clean coil first this may correct problem . if not , the the cold control may be failing so replace it next .. and clean it reg . as it will nt cool when dirty .. mm
Jan 07, 2010 | Refrigerators
I have a rooper top frezer refrigerator the refrigerator does not get cold because the ducts that connect to it freeze, I change the timer,check the heater,is good , change the defrost thermostat, but...
it seems to me that you have a clogged drain, that is located in the freezer compartment behind the panel. make sure that is not clogged. that will cause the issue you are having.
Oct 21, 2009 | Roper RT18HDXKQ Top Freezer Refrigerator
Refricerator/ Frezer is on and runing but not frezing or refricerating
On front of refrigerator and near floor remove kick plate and look for a small box with a hole in center. If you find the part I want you to turn the center clockwise slowly until the refrigerator stops or starts. I may be stuck in the defrost position. If it begins to work we need to replace the timer. Let me know what you find, Thanks, Sea Breeze
Apr 23, 2009 | Refrigerators
Kenmore Refrigerator Model #25357677791
stuck defrost timer/ thermostat. id go with both stuck because I'm looking at a diagram of your fridge now and there wired together.
i'd recommend changing both of them.
hope to be of any assistance.
Apr 26, 2008 | Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
