Question about Texas Instruments TI-83 Plus Calculator
The first row number (1-3) does not work, no response to the number. Everything else work fine
    Problem Solver:
  • 10 Answers
Call/email the product service center and complain
Posted on Dec 10, 2009
How to delet empty rows in excel
I am assuming you are using Office version 2003 or newer.
Towards the left border of the sheet there are row numbers; Left click on any number selects the entire row.
Once selected, right click on the row number or anywhere on the selected row and delete from the menu.
To select multiple rows:
1. Hold down the left mouse button and drag till you reach the desired end row. (row selection to be done by clicking on row numbers and not the actual rows)
2. Select a cell (left click), then the combination ctrl+shift+rightArrow. This will select the entire row (only if it is empty). Now use shift+downArrow to select one row at a time or ctrl+shift+downArrow to select all adjacent blank/non-blank rows.
If row number are not visible:
In Office 2007 goto "View" tab. Select "Headings" from the "Show/Hide" group. In other Office versions, use the menu navigation to reach this point.
Jul 11, 2014 | Microsoft Office Computers & Internet
How to number a column. I can't remember the short formula, something like a1+1= which would make the number two pop up in the cell underneath.
You can number rows in a column by entering a number in cell A1 (usually the number 1 but youcan start with any number) and the formula (=A1+1) in the next row. The result there will be 2. Copy that formula down the rows you want to number and they will be numbered 3, 4, 5, etc. Each row adds 1 to the previous row so if you do anything that disrupts the sequence (like inserting a row between two others) you will have to copy the formulas down again to restore the sequence. You can also use the Edit-Fill-... menu command to put a series of numbers into rows. Put the starting number in th efirst row. Highlight it and the rows that you want to number and select Edit-Fill-Series... Those numbers will not change if you insert columns or move the formulas.
Or you can use the formula =ROW(A1) in any cell to return the number of that row. (The result of =ROW(A1) is the number 1 in cell A1, the result of =ROW(A2) is the number 2 in cell B2, etc. In this case inserting rows will not affect the numbering (i.e. row A5 will always be numbered 5 even if the data in it is moved down.)
Sep 18, 2009 | Microsoft Excel for PC
Bottom of Touch Screen won't respond
Id try going to settings, general, reset and try that, but id do a sync firstly so you don't accidentally lose everything......
Dec 19, 2017 | Apple iPhone 3G Black Smartphone
Flashing light - TV shuts down
I will need the model number of your set in order to help you, but different models have different meanings for the error code. Your set is flashing an error code. Please respond to this and I will be able to help you with the problem.
Jun 15, 2008 | Sony Televison & Video
Exel
Do you mean the numbers down the left side? If you are missing a row number, it may be hidden. Get it back with these steps:
Push Ctrl + A (selects everything)
Click Format, then Rows, then Unhide. The row number should be back now.
Hope that helps.
Feb 18, 2008 | Microsoft Excel for PC
Upgrading power supply
The next time you get a PSU. Tell them what you have. Apparently you got one that is not compatible with your compaq.The power (500 wattage) will work with your MB.
Get an OEM PSU from Compaq(HP).
Dec 02, 2007 | Compaq (253219-002) Motherboard
Excel functions
Here's one way to do it. Your formulas would look like this:
B1:
=IF(OR(J1=1, J2=1, J3=1, J4=1, J5=1),1,0)
B2:
=IF(OR(J1=2, J2=2, J3=2, J4=2, J5=2),2,0)
B3:
=IF(OR(J1=3, J2=3, J3=3, J4=3, J5=3),3,0)
etc.
If you don't want the zeroes to display, format the cells with a custom number format--type: 0;-0;;@
Nov 14, 2007 | Computers & Internet
I can't fax! BUSY/NO RESPONSE
go into menu
go to fax settings
find send
click auto not manual, please make sure that when you push the hook key you hear a dial tone. always reminder that every fax machine has the capablitiy of either dial or tone. now if everything is set up properly  the problem will be in the tx portion of the board. if you can link up with somebody close to you and try to transmit back and fourth that will let you know if it is their problem or your. it may not be your problem.
Oct 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
Spring w/2 tiny rollers loose
On my i455 all the rear slots are occupied. The front only has 2,5,7, 8 occupied. It works fine that way. I think the rear is more critical than the front to proper paper feeding. Good luck
Jan 16, 2007 | Canon i 450 InkJet Printer
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
