Question about HP Pavilion dv9000z Notebook
Screen goes to red and white - HP Pavilion dv9000z Notebook
    Problem Solver:
  • 5 Answers
There is something wrong with ur screen. send in for repair if its still under warranty
Posted on Dec 10, 2009
SAMSUNG LD TV - VIDEO PROBLEM
Make sure that your video is connected to the video port on your TV. Also check to see if you are using the proper channel (component) on your TV.
Most issues occur when the cables are plugged into the wrong port. Some are color coded. Red goes to red, white goes to white and yellow goes to yellow.
Sep 18, 2016 | Samsung Televison & Video
Red dots on screen
Look for any loose contacts in RC jack, cable, connectors. Try using a different input device.
Aug 13, 2012 | Samsung PN51D550 51 3D HDTV Plasma TV
Wii does not show up on the tv screen
This problem is likely due to a problem with your AV cable. Try the steps below to get your Wii up and running.
  • Make sure the Wii is turned on and all cables are plugged in.
  • Unplug the AV cable from the T.V. (The AV cable has a red plug, a yellow plug, and a white plug.)
  • Plug the AV cable back into the television making sure that the red plug goes into the red socket, the yellow plug goes into the yellow socket, and the white plug goes into the white socket.
If problems continue try replacing your AV cable with a new one.
Jun 16, 2011 | Nintendo Wii Console
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
Red light and screen flashes white
99% sure you have a broken flatcable that is going to the upper screen.
Only solution is to replace the screen (cable is attached to it and cannot be replaced seperate)
John
Nov 04, 2008 | Nintendo DS Lite Console
Power connection
Yes. White goes to ignition (switched 12VDC) Red goes to constant.
Oct 05, 2007 | Radio Communications
White flashing screen & red light permanent
this complaint is probably software complaint so flash your phone
Jun 29, 2007 | Sony Ericsson K750
HP Pavilion dv9000z Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
