My 19" tft lcd monitor has a slight problem with the screen. the problem is that when i look close at some points there is a slight fuzzyness around the edges on some graphics namley blue, black and red areas. sorry its a bit difficult to explain.
  • 91 Answers
Check your resolution settings , and screen dpi settings.
Posted on Jan 20, 2008
My lcd is hpl1908w its display goes of 5 minutes on first starup and when its displays goes off i on and off the monitor display comes for fews seconds and then goes off again lcd light is green but...
well if your lcd has no bulge capacitors test your tft lamp both top & down of the screen( particularly top) with spare tft lamp. or use another screen to test it. secondly, test the c5607 transistors in the inverter section but if you know how to use spare tft lamp very well , you will easily detect between your screen & the inverter
Aug 06, 2015 | HP L1908W 19" LCD Monitor
I have a FPD1975W tft LCD monitor and the screen will blink on but then shut off. the power button still shows on though. i've checked all connections and did a cleaning as well but cant get the monitor...
The description points to the inverter board which energizes the back lights behind the screen, and is on the verge of failure. The cause is usually bad capacitors, the board will need to be replaced or a attempt to repair the existing one. If a professional gets involved the parts and labor can run high.
Feb 09, 2011 | Gateway 19" Widescreen Flat Panel TFT LCD...
My 19" TFT LCD monitor
Power capacitor problem, needs taking to a qualified TV repairshop to have the capacitor replaced / checked
Dec 28, 2010 | Xerox XA7-192i 19" LCD Monitor
Everything is too big on the screen when I get on the internet
Try selecting a much higher resolution from the menu
1650x 1200 should be ok for a 19" or 1260x760 or something within those parameters
Please rate my help++++Thanks for using FIXYA
Oct 20, 2009 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Installed 19 in tft-lcd monitor on new vista computer, used dvi-d input, screen is flickering
You need to up the refresh rate. Your settings may be slightly different to mine but this is how I get to it:
  1. Right-click on the desktop, select Personalize, Display Settings.
  2. Click Advanced Settings, select Monitor tab.
  3. Change Screen Refresh Rate to the highest number that is available.
Sep 08, 2009 | SVA-USA Computers & Internet
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Emachine 19" Widescreen Flat-Panel TFT-LCD Monitor
Your power/inverter board is in need of an overhaul.
The capacitors are failing and possibly a transistor.
If the screen showed any redness or pink whebn it was working, Then there is a slight chance that one or more of the 4 lightbulbs in the screen was going bad and finally went.
If you take it apart and send me a picture, I may be able to tell by looking at it.
I repair these boards on ebay
bammbammfran
Nov 05, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
19 inch tft lcd monitor blurry
go to control panel click on display icon and then go to setting tab and there you will find screen resolution settings
Apr 29, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
David Payne
David Payne
