I plugged my Sony Qualia 004 SXRD projector in and it doesnt power on at all. I checked the fuse and it fine. please help
SOURCE: sony projector
Hi there
Check if your lamp is blown by taking it out and looking for any marks or discolouring on the inside of the lamp.
If the lamp looks fine , it could be that your Ballast ( lamp's powersupply ) is faulty.
SOURCE: Sony VPL-DS100 will not turn on
I had same problem. The cause was a blown fuse (T5.0 Amp 250V). You have to open the case and then get below the print that is under the alloy cover. it is quite simple to fix. A fuse costs 60 cents.
SOURCE: Sony VPL-CX5 projector won't reset after power
Please go to menu and check auto power on if it is on make it off
SOURCE: Sony Projector won't turn on
Its because bulb ballast circuit problem.You have to replace it
SOURCE: sony vpl cs5 projector will
Have you tried the following: Connect the power cord and turn the projector to standby mode. Press the following keys on the remote commander in the following order for less than five seconds each: RESET, <,>, ENTER.
