Jenn-Air Gas Slide-in Range mdl JGS9900BDB: The solution I received was to replace the control board, which I did; no difference. The same problem persists with the new board. That is, The display is limited to the time and the only buttons that work are the two center top keys (timer 1 and timer 2). The numbers key pad beeps but doesn't change the display. All the other keys are dead. Please help.
Comments:
Dec 12, 2009
- I've checked all electrical connections I could find. No difference. Can you help me pin point where the connection problem might be? Thanks.
Dec 18, 2009
- I dug into the range further and found that an assembler in the factory failed to run two red wires from the control board to the meat probe through a hole in a nearby box with the rest of the wires. Instead, the assembler clamped the wires under the cover to the metal box under the lid which, over time, cut through the insulation on both wires, thus "grounding" or shorting them out. Would that have been enough to blow out my control board? I've since repaired the wires and am waiting for another control board, assuming I've fixed the problem that led to the board's failure. What do you think?
Dec 19, 2009
- Thanks for the guidance. I am hoping the next control board (on back order) I install will, in fact, work. I'm optimistic!
Hi ,you will need to replace control panel part # w10206073 cost about $175 and is currently on national back order,try making sure the ribbon connector between the panel and board is tight and clean.Hope this helps. Please rate my response :)
can I terminate a vent into a appliance chimney that also serves a hot water tank? This is a Jenn...
(More)(More)
can I terminate a vent into a appliance chimney that also serves a hot water tank? This is a Jenn Aire gas stove.
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
How do you fix an electrical short under the top fan switch on a Jenn Air gas/electric stove? Can I...
(More)(More)
How do you fix an electrical short under the top fan switch on a Jenn Air gas/electric stove? Can I remove the top of the stove without removing the stove from the cabnet?
Posted. Thank You!
When turning on my oven it takes a while to preheat. It also can take a while to cook for example I...
(More)(More)
When turning on my oven it takes a while to preheat. It also can take a while to cook for example I tried to bake a cake and after three hours it was not cooked!!! It also can smell like gas sometimes at which point I shut it off immediately. The burners seem to pulsate as well. I have replaced so many parts and am just wondering if this can be fixed or do I need a new oven? Please help!!!
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
