Question about Kenmore 54501 Dehumidifier
Filter is stuck in frigidaire dehumidifier. Can't remove to clean. Model FDF70S1
Changing the filter on a Frigidaire dehumidifier model no. FFAD5033R10
Hello Paul, thank you for your post!
From my understanding you need help changing the filter on your Frigidaire dehumidifier. I have located a copy of the manual and on page nine it will provide you with proper instructions on how to remove the filter. Best of luck! -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Edison/66129917125en.pdf
Apr 06, 2016 | Frigidaire Dehumidifiers
I have a Frigidaire Dehumidifier, Model FAD704. the Clean Filter lights keeps coming on and the unit stops running. The filter is not dirty. I take it out and put it back in and unit runs for awhile and...
Hello Winl, thank you for your inquiry!
I see that you are having issues with your clean filter light coming on in your Frigidaire dehumidifier. From what you are describing it sounds like a possible issue with a sensor within your dehumidifier. I would recommend consulting with your manufacturer to see if they can provide any additional assistance towards a resolution. Best of luck! -OOS
Dec 12, 2014 | Frigidaire Dehumidifiers
What should I do when the air filter light comes on?
Good Afternoon Friend, that's a great question!
Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
Sep 11, 2014 | Frigidaire FDL50R1 Dehumidifier
Removing the filter model fdl7051
Hello Friend, this is Z. Thank you for allowing me to assist you!
You would need to remove the bucket to locate the filter of your Frigidaire dehumidifier (FDL70S1). Then pull the filter downwards for cleaning. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions and typically the FILTER REST light will illuminate after 250 hours of operation. Hope this helps!
Aug 12, 2014 | Frigidaire Dehumidifiers
How to locate and replace internal filter?? For frigidaire
I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps.
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, and then replace Bucket.
I have also included the link for your manual, where I found these instructions. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
May 30, 2014 | Frigidaire Dehumidifiers
How to clean the filter
Good Afternoon Tad, thank you for allowing me to assist you!
First remove the bucket to reach the filter of your Frigidaire dehumidifier, FAD504DUD. When you locate the filter, pull it downwards. The filter can be clean by either washing it with clean water or using a vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once the filter is reinstalled then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier will resume normal operations.
Hope this helps!
Jan 31, 2014 | Frigidaire Dehumidifier Fad504dud
Hello , I have goldstar dehumidifier model #DH40 . It's freezing from back grill? Can you please give me some solution to it? Thanks for you're help
It sounds like not enough air flow. clean the filter. I would suggest unplugging it and let it set for a day to dry out then replace filter and clean the air path including coils.
Jan 10, 2014 | Frigidaire FAD704DUD Dehumidifier
Dehumidifier smells stinky
Have you read its manual? http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
It says (p8):
Care and Cleaning
1. Filter
d. Re-install the filter, then replace Bucket.
2. Cabinet
a. Dust cabinet with an oil-free cloth, or using a damp cloth.
b. Vacuum grill using brush attachment.
3. Water Bucket
a. Clean bucket with warm water and detergent.
I recommend you to use a mix 75% water, 25 % vinegar. To clean its water bucket.
Oct 01, 2012 | Frigidaire FDF70S Dehumidifier
Frigidaire 70 pint dehumidifier model # LAd704TDK filter looks to have frozen or clogged, how to remove filter to check for problems?
Turn the unit OFF & unplug it. Remove the water collection bucket and set aside. At the top of the bucket holder, just behind the louvers you should see a plastic pull tab, which is part of the filter frame. If you have never removed the filter before, there may be a piece of plastic tape on the filter frame. It was put there for shipping. Remove and discard it. Pull straight down on the plastic tab and remove the filter. It can be cleaned by vacuuming it or if it's really dirty, wash it in with warm water and mild dish washing liquid. Rinse thoroughly, shake off access water and allow to completely dry, before reinstalling it. Never operate the unit without the filter in place, as doing so could cause damage to the unit. The filter should be removed and cleaned once every two weeks.
Hope this helped you and thanks for choosing FixYa.
Sep 20, 2011 | Frigidaire Dehumidifiers
Just wondering if this unit has a filter or filters that need to be changed?? (Frigidaire 70)
Yes, your unit has an air filter, that should be removed and cleaned at least once every two weeks, while in operation, The filter is located behind the louvers on the front of the unit. To access and remove it, remove the water bucket and just inside the bucket holder at the top of the opening, you will see a tab type of handle. This handle is part of the filter frame. Pull that down and out and the filter will come with it. Back flush the filter with clear warm water. Dry it thoroughly, before reinstalling it in the unit. Never operate the dehumidifier without the filter installed.
To assist you further, in case you have misplaced your Owner's Manual, I have included a link to the Manual for your model. You can download and print the manual for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Hope this helped you. Please let me know. Thanks.
Jun 25, 2011 | Frigidaire FDF70S Dehumidifier
Kenmore 54501 Dehumidifier Logo
195 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
