Question about Linksys Wireless-G WRT54G Router
Linksys wireless G-ADSL Home gateway
Hi
I was using my wireless laptop and it just went off and i cannot now get the wireless connection to work. It says no connection found.
please help
    President:
  • 2,351 Answers
Sometimes this happens. Installing the Linksys software for your router helps a lot. To reset the router. Unplug the power cord from the wireless & unplug all cables to it. There is a reset button on the back side of the wireless. It is very small. Using a pen press & hold for ten seconds or so. Release & connect your cables & than the power cord. Never hurts to restart the pc or notebook. If you still need help you can check out Linksys home page for wireless G routers.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
There is a decent ammount of help, a larning center & driver software.
Luck!
Please vote....
Posted on Jan 24, 2008
I LOST MY Linksys WirelessG ADSL Home Gateway WAG200G Wireless router CD
Download the firmware from the Download tab after following the link. You should be able to find user guides and other help for your router there too. Downloading the firmware should allow you to use the router. The CD just contained that info.
Link
Nov 29, 2012 | Linksys WirelessG ADSL Home Gateway...
My wireless is going on and off, what's the problem?
Frequent wireless disconnection can be caused by different factors such as:
• Wireless interference within the network
• Wireless settings of the Linksys ADSL gateway are still set to default
• Firmware is corrupted
NOTE: Before going through the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
To resolve intermittent wireless connection, you need to perform the following steps:
i. Reducing Wireless Interference
ii. Customizing Wireless Settings of the ADSL Gateway
Nov 11, 2010 | Linksys Wireless-G WRT54G Router
Linksys WAG200G doesn't have a green light with the internet.
Try unplugging the WAG200 ADSL Home Gateway, leave it off for a minute, then plug it back in. Sounds too simple, but it works more than half the time.
Apr 14, 2009 | Linksys WAG200G Router
''Network Cable Unplugged'' problem on Linksys but not on D-Link
Most likely the connection inside your new gateway is bad - you should return it under warranty & get a new one.
Apr 13, 2009 | Computers & Internet
Appreciate any advice on how to set up Linksys Wireless G Router
here's a basic SoHo set-up.
But if your looking for manual, please provide me your e-mail address so that i can e-mail you.
Thanks.
Feb 09, 2009 | Linksys Wireless-G WRTP54G Router
Internet access problem with a Linksys 54g router
Try setting the default gateway on the laptop to the ip address of your ICS gateway machine. Some routers separate the wireless and LAN connections on different subnets.
Try comparing your laptops ip information with that of one of the working wired computers. You can do this by going to Start up to run and type cmd then click "ok"
At the black prompt screen type "ipconfig" without the "".
You want to compare the IP Address, Submet Mask, and Default Gateway.
If one has an ip of 192.168.1.* and the other has 192.168.0.* then the wireless and wired are on seperate networks.
If the subnet masks are something like 255.255.255.0 and 255.255.255.1 they are on seperate subnets. Both should be fixable by putting in the same default gateway.
For example if your ICS gateway is 192.168.1.1 then set that as the default gatway on the wireless laptop. This can be done by going to start >> Control Panel >> Network Connections then right click your wireless connection and goto properties then double click on the "Internet Protocol (tcp/ip)" option. This will list all of your ip information (if its static) if its dynamic (ip gotten from router) you can still click "Use the following DNS server address" and set preffered dns to the gateway ICS ip. Or click "Advanced" and click Add under Default Gateways and add the gateway ICS ip there.
Jun 20, 2008 | Computers & Internet
Router does not hold the internet signal effectively
Can you please tell me whats the current Wireless Mode? have you perform reset?
Jun 19, 2008 | Linksys Wireless-G Broadband Router
Can not connect adapter to laptop no installation CD-Rom
you have to install the driver for it to work and i assume that is not the case as you have no cd. Go here to download the driver. http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1134691790190&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0993490190B03 When installed go to the properties of your adapter in network connections, then click on tcp/ip line and then properties and ensure obtain ip address automatically is ticked and press ok. You may also have to use the home network connection wizard if you havent previously to share documents over your network.
Apr 13, 2007 | Linksys Wireless-G WUSB54G 802.11g/b
LINKSYS WIRELESS - G WAG54GS
Diana, The router has lost its IP address from the ADSL gateway. Unplug the router from the wall for about a minute or two. Plug it back in..? If that doesn't work you need to login to your router and check the settings. or(there is a small reset button on the back of the router. Hold it in for 10 seconds the router will reset.) http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper If possible turn your computers off while resetting the connection. Some inter Microsoft networks will issue its own IP if it doesn't detect one. Good Luck, Tim
Feb 07, 2007 | Linksys Wireless-G WRTP54G Router
Linksys Wireless-G WRT54G Router Logo
182 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
