Clean pump good evening. In my last wash, the light for "clean pump" appeared, and the wash was not completed, and there was still lots of water inside the machine at the end of the wash
  • 478 Answers
Sometimes a sock or something small gets sucked into the pump that pumps out the water on some brands of washers (depending which washer you have) take the back off the back of the washer (after unpluging and turning off the water feeds) locate where the pump is and look to see if theres something inside the tube with a pair of pliers you can take the clamp off and exstract the blockage and replace the hose + clamp and after cleaning up the water try to run the washer again if things work finsh pulling the washer back together
Posted on Dec 09, 2009
Testimonial: "thank you for your feedback, we shall try that"
My Kenmore Elite HE5t is acting funny. A lot of different symptoms in the past few days. 1. Door locked and would not reset so I pulled front cover below the door and reached in and pulled the manual...
It sounds like the panel has had its day, and the door latch has as well.You don't say the age of the machine. But nowadays nothing is made to last. You can live without a washing machine. Just soak your washing in soapy water over night in the tub and rinse it out in clean water in the morning and hang it out to dry. If it is raining hang it under cover or squeeze as much water out of it as you can and put it in your dryer. Hopefully you have one and it is working.
Aug 19, 2014 | Washing Machines
Bosch nexxt 3200 washer
It could be the pump is restricted and would not pump all the water out. The pump should be clean for every 6 months to avoid blocking. In worse case the propeller inside the pump is not as good as it was, and may need to replace.
Oct 23, 2013 | Washing Machines
Kenmore Elite, HE3t, front loading washer, Model 110.45972404. Constantly shuts down during cycle with SUD or F02 signals. If I pause and restart sometimes it works. However last night it would not drain...
F02 indicates the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Take care of lot of water going to the floor, unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
I think the drain pump is clogged due to SUD formation.
The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya.....
Jul 08, 2010 | Kenmore Elite 45986 Front Load Washer
What does problem f2 mean
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Take care.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 02 was flashing and the water is still in the machine how do i get the water out
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
Jun 20, 2010 | Kenmore Elite 45986 Front Load Washer
What does F2 code mean with the Kenmore Elite HE3?
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Series 70 has musty smell and sounds like water inside
The water will always be in there. It is in between the basket and the drum. That is normal. However if you want to get rid of the musty smell there is a good tip that I have. You can find this on my profile too. Just take about a cup of white vinegar and put it in the drum and wash on hot heavy load. This will clean the tub and all hoses as well. You can do this every few months or even every month if you do a lot of laundry. Put some vinegar into the bleach dispenser too and the fabric softener area as well. This way you will clean everything. It is much cheaper then going out and buying that expensive cleaner made for washing machines. Let me know if you have any other questions and if this was helpful. Good luck and have a great weekend.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
Front loader washing machine is not draining
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Be prepared to catch lots of water. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Whirlpool Washing Machines
Flashing F and alarm
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.... Hope this helps
Jun 08, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
