Question about Frigidaire Dishwashers
MY DISHWASHER DOES NOT DRAIN THE WATER OUT AND IS MAKING A RATTLING NOISE.
  • 25 Answers
Pull the pump motor and see if the impeller has come loose or fallen off for the rattling noise.
Also check the drain valve and hoses for crimps or obstructions.
Posted on Dec 09, 2009
SOURCE:
My LG Wahining machine is making a rattling noise and will not spin or drain.
For the washer to spin, it must first drain the water out of the tub. Since you are hearing a rattling noise, and your washer will not drain, most likely the problem is the drain motor itself. The impeller wears out on the shaft, and start to wobble, and make a vibrating/rattling noise.
Sep 23, 2014 | LG WM2487H Front Load Washer
Fridgeair dishwasher not working making loud sound. water comes in and I can make it drain out but washer does not start
Hello
bearings in the heater fan may get worn out or rust. If this happens, it may become very noisy, either grinding on the bearings, or scraping against the rust. If this happens you need to replace the fan motor. Sometimes, a fan blade may come loose, and you need to replace it.
Sometimes it's the motor that makes the noise you hear. The motor has bearings in it which may become worn or get rusty. When the bearings get worn, they allow the shaft to wobble which can get quite loud. If there is a spin seal leak, water may get inside the motor, washing the bearing grease away. If the spin seal is leaking, you'll notice water leaking from under the dishwasher. There is also a disc attached to the top of the motor called a slinger. It sometimes breaks off and spins around the motor's shaft while it turns, causing some noises. You will need to replace the motor if the bearings are bad. You also need to replace the motor if the slinger is broken as well.
Newer dishwashers may make a squealing or rattling noise on the first run. This is because it has not had any water in it yet, and the motor seals are dry. You may hear this in a unit that hasn't been run in a week or more as well. You should operate the dishwasher regularly to keep the sump water from getting smelly, and to keep the seals lubricated. You can add a quart of water to the sump before running it.
Rattling noises may be produced by dishes rattling inside the dishwasher due to the water pressure from the sprayer arms on the dishes. To determine if the rattling is a loading issue, run the unit empty. If the sound is persistent, it may be that there is debris in the pump.
dishwasher water-inlet valves are noted to make a hum that lasts about 60-90 seconds several times during a washing cycle. This hum is a different hum than the sound of the motor running.
A rhythmic knocking or thumping sound may be caused the sprayer arms hitting something as they go around and around. Rearrange the dishes and resume the wash.
A clunking or clanking may be heard when the detergent cup opens; while a clicking sound may be produced by the timer or electronic control panel.
A solenoid makes a snap sound when it opens. This happens about six times during each load.
Pipes rattling or banging may be caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The sound is caused by the water slamming into the closed section of pipe. A plumber can install an anti-hammer device.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and then remove the item that is making the noise or replace the pump. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher.
Send this page to your printer
Aug 06, 2011 | Dishwashers
My dishwasher won't drain and there is a rattling noise in the door. I don't know if I should just get a new one as the repairman costs are high. I did start a cyle over and more water went in but...
there is a drain pump system on the machine could be clogged, also if the drain hose is not installed up and over the unit it will cause issues with drainage. as for the rattling noise you probably have either pieces of broken glass rolling around under the basket.if you are a do it your self-er its always fun to explore.if not the cost of repair would be the cost of a new install. don't waste your money.
Jun 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
My washer is making a rattling noise as if the water is not leaving the machine. I checked the hose...nothing....now my washer has water in it
does your washer spins?. the most common cause would be a sock caught in the pump blocking the water drain and making noise with the pump impeller.
Feb 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
Dishwasher is making a loud pipe rattling sound
The water supply line has not been secured properly. Turn off breaker, open DW at bottom and secure water line.
Sep 26, 2009 | Asko D1706 Built-in Dishwasher
Whirlpool Duet 9100 starts cycle then stops & wont drain
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
Mar 24, 2009 | Whirlpool GHW9100L Front Load Washer
ASKO dishwasher won't drain and makes rattling sound.
I had tried several failed attempts to fix this problem. Finally I got on my knees and asked God to make the dishwasher run in Christ's name. The dishwasher just completed it's first cycle without any problems.
Feb 10, 2009 | Asko 24 in. D3121XL Free-standing...
Noisey pump
Take the drain pump apart and look for debris, or broken pump impeller. Remove the lower spray arm and filter assembly, check for debris in the sump and check the drain check vavle to make sure it is sealing properly. While in there make sure the food disposer blade are not clogges with debris.
Jan 26, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Noisy dishwasher
Your motor is makinig all the noise.
Jul 15, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Dishwashers Logo
205 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
