Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Steam valve not closing
This is a recurring problem and the service people at the Ohio facility don'tr seem to be able to fix it.
It started with my Incanto Rondo that I took back about 5 times (luckily for me, I work within 5 minutes from their facility). After a couple of weeks of use, it stopped steaming the milk, steam was running out inside the machine, through the steam valve. If I took out the brew group and jiggled the little plastic piece at the bottom end of the steel pin (between the two o-rings), it would snap down and I could steam a cup of milk.
After the next brew cycle it would hang up again.
On and on and on.
Saeco actually gave up and give me a Sirius in place of the Rondo. It worked fine for about 3 months and it too now developed the same exact problem.
Any ideas?
  • GrandpaMike Jan 19, 2008
    Sorry, that's definitely not it because I only use bottled distilled water, to prevent scaling.
  • 2,039 Answers
Grandpamike im pretty sure our a guy it lot of experience in coffee machine you probably already know that but maybe in our city the water very hard . maybe you have calcium in water valve a couple of descaling maybe the solution take care grandpamike cheers
Posted on Jan 19, 2008
Random recurring buzzing sound.
Local results for television repairs Toledo Ohio Bing Local http://www.bing.com/search?q=television+repairs+Toledo+Ohio+&qs=n&form=QBRE&pq=television+repairs+toledo+ohio+&sc=0-14&sp=-1&sk=&cvid=047a43a19bff4df998a213e38cb181ce
Oct 28, 2015 | Televison & Video
Hi My Miele Coffee System seems to have developed a problem where when i use the steam wand and then close the wand off steam still spits out for about 30 seconds. Is this something i can fix myself or do...
I have the later model (CVA 4070) and the setup is lightly different. I have not worked on your model however I think there are only two parts that need to be checked. 1. Steam Valve (located in door and part of the steam knob). This is the likely cause and the problem is that it's either dirty and can be disassembled and cleaned or it has worn parts inside that need to replaced. 2. Steam Solenoid (inside unit before steam heater). These generally block and thus result in lower pressure but perhaps this one is having trouble closing. If your technically minded I would disassemble steam valve in door and clean and inspect all parts then re-assemble. If this does not fix problem then replace any suspect parts in the steam valve. ie o-rings. Testing 2 is more complex. You could do this via the Service Mode. Please Note ... DO NOT WORK on this machine unless power plug is removed from mains socket. Regards
Sep 01, 2013 | Miele Coffee System
I have a 2000 cougar that wont start when it sits for more than one hour,
Hmmmmmm....this one might have to go to FORD to be fixed.Have you replaced the fuel filter?
That's probably not what's wrong, but if it's been a while,it won't hurt to change the fuel filter anyway.
Keep any source of spark away(trouble light,electric cord,etc.)when you take the hose off.Of course relieve the pressure at the fuel rail relief valve before attempting.
don-ohio (:^)
Jan 01, 2013 | 1999 Mercury Cougar
TR 019 STEAM SHOWER leaking water from every jet, body jet , foot massage, shower head, top shower head when in off position
Tr019 is a type of control panel that operates the electrical features in a steam shower cabin, usually found in Chinese products. The issue you have is with the valve, in particular the on/off valve. These can be replaced individually or as a complete new valve . This company in uk sell them http:// www.steamshowerparts.co.uk
Aug 12, 2012 | Home
My back up lights dont work. checked the bulbs. Is the five speed manuel trans. Any ideas
Check the switch on the tr-a-nny. It might be bad, or the wiring leading from it could be bad. don-ohio (:^)
Nov 27, 2011 | 2006 Kia Sorento
E511 error code
  1. Check of Photoconductor Unit attachment. Re-attach Photoconductor Unit.
  2. Is the Drum of Photoconductor Unit rotating?
  3. Remove Photoconductor Unit. Turn gear of Photoconductor Unit until silver seal attached to Belt can be seen.Is silver seal dirty?
  4. Remove Photoconductor Unit. Is SENSOR TR-0 attached securely?
  5. Remove Photoconductor Unit. Are there any dirt or foreign bodies on the SENSOR TR-0 surface?
  6. Does the error recur when the power is turned ON?
  7. Remove Photoconductor Unit. The voltage of P416-2 ↔ P416-3 on PWBA MCU is 5 VDC when silver paper or other reflective object comes close to the sensing area of SENSOR TR-0, and is 0 VDC when the object is released?
  8. The voltage of P416-1 ↔ P416-3 on PWBA MCU is 5 VDC?
  9. Disconnect the P/J416 from PWBA MCU. Do all of the wiring below have normal continuity?
  10. Replace MOTOR ASSY P/R.
Jun 19, 2009 | Epson Aculaser C1100 Printer
Saeco Odeo Giro Plus dripping steam wand
I don't know any of the suppliers in the UK, but yes the problem can be fixed at home, it is very easy to replace the steam valve, just make sure that you get the complete valve(body and tap rod). Try this site they might ship the parts to you (saecoparts.com)
Jun 09, 2009 | Coffee Makers & Espresso Machines
Epson CX11NF Error Message Service Req E511
This is from the service manual
Service Req E511
�� Possible parts that caused the error�� Troubleshooting
�� Photoconductor Unit �� SENSOR TR-0
�� HARNESS-ASSY XERO �� MOTOR ASSY P/R
�� HARNESS ASSY MAIN �� PWBA MCU�� LV/HVPSStep Check Yes No
1 Check of Photoconductor Unit attachment
ON?
Go to Step [2]. End of
procedure
2 Operation check of Photoconductor Unit
Go to Step [3]. Go to Step [10].
3 Check for dirt on silver seal on Belt in
Photoconductor Unit
Replace
Photoconductor
Unit.
Go to Step [4].
4 Check of SENSOR TR-0 (TR0 Sensor)
Go to Step [5]. Re-attach
the SENSOR
TR-0, and go to
step [5].
5 Check of dirt and foreign bodies on surface
of SENSOR TR-0
Clean to remove
any dirt or
foreign bodies,
and go to step
[6].
Go to Step [7].
6 Does the error recur when the power is
turned ON?
Go to Step [7]. End of
procedure
7 Operation check of SENSOR TR-0
Replace PWBA
MCU. (p.404)
Go to Step [8].
8 Check of 5 VDC power supply to SENSOR
TR-0
MCU is 5 VDC?
Go to Step [9]. Go to Step [14].
9 Continuity check of HARNESS-ASSY XERO
continuity?
J416-1 ↔ J108-3
J416-2 ↔ J108-2
J416-3 ↔ J108-1
Replace
SENSOR TR-0.
(p.361)
Replace
HARNESSASSY
XERO.
10 Check after replacement of MOTOR ASSY
P/R
Replace MOTOR ASSY P/R. (p.398)
ON?
Go to Step [11]. End of
procedure
11 24 VDC power supply check to MOTOR
ASSY P/R
Disconnect P/J201 from MOTOR ASSY P/R.
The voltage of J201-1 ↔ J201-2 is 24 VDC?
Go to Step [12]. Go to Step [13].
12 Continuity check of HARNESS ASSY MAIN
Disconnect the P/J403 from PWBA MCU.
Is the continuity normal between all terminals
of J403 ↔ J200?
Replace PWBA
MCU. (p.404)
Repair broken
or shorted part.
13 Continuity check of HARNESS ASSY MAIN
Disconnect P/J502 from LV/HVPS.
continuity?
J502-9 ↔ J201-1
J502-10 ↔ J201-2
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
14 5 VDC power supply check to PWBA MCU
The voltage of P410-3 ↔ P410-4 on PWBA
MCU is 5 VDC?
Replace PWBA
MCU. (p.404)
Go to Step [15].
15 Continuity check of HARNESS ASSY MAIN
Disconnect P/J410 from PWBA MCU and P/
J502 from LV/HVPS.
continuity?
J410-3 ↔ J502-3
J410-4 ↔ J502-4
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
May 22, 2008 | Epson Aculaser C1100 Printer
PUFF OF STEAM,CONDENSATION,GRINDS LONGER
The steam and leaking in the upper right corner turned out to be a leaky valve. I may have been able to fix it by just replacing the O-rings. However, the only place I found to get the right rings was in the kit to replace the steam valve assembly.
Aug 31, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
246 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
