Question about Dishwashers
The dishwasher and chemical dispenser are 30 years old. The chemical dispenser does not work properly. I think the seals in the tubes are worn. It is an auto chlor model l3. Can I get parts for this dispenser or is there another dispenser that will work with the Hobart AMES 12 dishwasher. The dishwasher works fine.
  • Charles Barton Dec 09, 2009
    Are there any dispensers that will work with this dishwasher?
  • Charles Barton Dec 10, 2009
    DOES ANYONE KNOW WHERE I CAN GET PARTS?
  • 5,081 Answers
Http://shopping.yahoo.com/s:Major%20Appliance%20Parts%20&%20Accessories:4168-Brand=Hobart
http://www.electricalsales.co.uk/productlist.asp?man=38
These are the links where you can buy hobart dishwasher parts online. If you want to buy it in a specific shop , please do specify where you live at.
Posted on Dec 10, 2009
  • INDIRA KUMAR
    INDIRA KUMAR Dec 10, 2009
    Did you check the link.
  • 3,917 Answers
No there are no parts available for the dispenser from another dispenser which is compatible with your Hobart AMES 12 Dishwasher. The official website to search for the same would be:
http://kitchen.manualsonline.com/manuals/mfg/hobart_corp/hobart_corp_dishwasher_product_list.html
Thanks
Posted on Dec 09, 2009
    Sergeant:
    Champion:
  • 278 Answers
Howdy: Stay with the orginal parts to be safe. Some may look alike but small changes could cause problems. Good Luck - Doug
Bosch dishwasher is not filling with water and detergent is not being released.
The soap wont come out if there is no water. Does the detergent flap open? If so, the dispenser is OK. If not, you need a new dispenser. If the machine is not filling, check the pressure switch and or the tubes that go to the pressure switch, they may be blocked, tricking the machine into thinking its already full of water.
Feb 27, 2015 | Bosch Dishwashers
I have a 2 year old GE dishwasher that the rinse agent dispenser stays full & the product never comes out or works. My dishes come out clean, yet spotted.
If you are handy you could take the front panel aprt and see if the tube that connects to the selonoid to dispense at the proper time is plugged with crystallized chemical or it could be broke and just leaking out the door and into the bottom of the dishwasher.
Jul 25, 2014 | Dishwashers
Lxi hobart not pulling rinse aid i used a screwdriver across prongs on board to make it run manually but still not coming out
try replacing the "squeeze tube" inside the dispensing unit. Over time the tube flattens out. If the tube is flattened no chemical will be drawn from your jug.
Disconnect inlet and outlet hoses on rinse aid dispensing unit.
Remove 4 screws and pull off outer face of dispensing unit. You can watch the dispenser operate with the face off if you wish, as long as the hose doesn't fall out (which it won't).
Remove squeeze tube and install new tube.
Reassemble inlet and outlet hoses (be sure to not mix up which tube/hose goes on top and which on bottom).
Also possible that the hose from the chemical jug to the dispensing unit has a hole/crack or otherwise. If the hose has a leak it'll lose suction and draw air in from the leak and not pull chemical.
Nov 19, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Clorine test by county health failed, what
The first thing I would check is the chlorine pump's element tube (squeeze tube) The element tubes often get worn out and stop drawing chlorine through the pump and into the wash tank. Most chemical supplier will have these element tubes. The element tube is located in the chemical pump. The chemical pump is usually located just inside the front lower service panel of the machine.
Regards
Apr 09, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
My am-14 is eating the detergent. It use to last a month now less than one week. Is there a soleniod valve thatisn't closing?
The over consumption of detergent could be caused by a couple of things. If the detergent is dispensed by an external chemical pump, the detergent probe may not be working correctly. The probe will cause the pump to dispense too much chemical if it is dirty or has hard water build up on it. You can check the probe and clean it of any debris. The probe is located in the bottom of the wash tank. Most chemical suppliers take care of these sorts of issues at no cost to the customer. If your rinse solenoid is not closing properly, this could cause the detergent to flow down the standpipe (overflow drain). This would make the chemical pump dispense detergent more often then usual. An easy way to check if your rinse soleniod is stuck open is to look at your rinse arms if water is flowing out of them and doesn't stop this would mean your solenoid is in need of repair.
Kind Regards
Feb 26, 2010 | Hobart AM14-253 Free-standing Dishwasher
I have a three year old Hobart. I am not sure
Look on the top edge of the door to find the data plate. It sounds like an SR24, if the leds are on the left of two temp gauges. If your sanitizer pump has a tired silicone tube that is flattened from use, it will not draw chemical. if you have an air bubble in the sense board at the back, it will think you have run out. If you have changed the type of chemical or diluted it, the board will need recalibrating to suit. Put some sanitizer in a small vessel with the pickup tube and monitor the amount delivered. Usually one is looking for 50 ppm solution of bleach and rinse water.( test with litmus paper) If you have an SR24H with a booster, you don't need bleach sanitizer and holding the sanitizer button will turn the sense off.
Jun 16, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Calcium build up and i need to titrate my chemical
If you are asking about mineral build up in a dishwasher, add approximately 2 cups of white vinegar after the dishwasher has filled with water an begins the wash cycle. Feel free to repeat after each drain/refill cycle until you see the minerals have dissolved.
Good Luck!
May 04, 2009 | Dishwashers
Rinsing agent dispenser empties too quickly
has the seal ring fallen away? is the flap shutting properly/ try setting it to a lower numbered setting.
Mar 14, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
BOSCH DISHWASHER SHU43C06UC/17 NO WATER UPPER ARM
Ours is a SHU3300UC/06 model, basic model which we bought in 1999 so have had 9 years of trouble free service.
Recently we noticed that there was soap left in the soap dispenser after the machine had finished all the cycles. On further inspection we noticed that the upper level glasses, cups and bowels are not consistently clean and it appears that the upper washing arm is not working properly. At the back of the upper washer arm, there is a rectangular piece that slides over the two water outlet tubes projecting out of the back of the washer which supply H20 to the upper arm. On removing the upper arm and the rectangular connector, I noticed there is an inner place that I think is supposed to work like a washer that fits tightly over the 2 water outlet tubes in the protruding from the back of the washer. I noted that the upper opening in the washer/seal is broken so a proper seal is not established. This would cause insufficient water pressure getting to the upper arm and reduce its effectiveness. Now I'm trying to find the replacement part. It appears to be something than can easily be replaced.
Dec 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh dishwasher shu3322uc/22
check for leaks where the the top rack plugs into the rear. it might not be sealing. If your unit has the ability to change the top rack height check in the other position and see if it works. In my Samsung (Bosch in disguise) model The tube to the top rack plugs into one of two holes in the rear, depending which rack position I use. Something covers the hole not in use. Bosch uses two seperate pumps for washing and draining. So I don't think the pump could go partially bad. (This happens in other brands when the solenoid gets stuck between pump out and recirculate)
May 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
100 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
