Question about Kenmore Dryers
Dryer tumbles but no heat. Replaced Thermal
Dryer tumbles but no heat. Replaced Thermal cutoff, heating coil. fuse and Control Board(had burnt resistor), but still no heat.
What part do I need?
tony
    Sergeant:
    Champion:
  • 278 Answers
Howdy: Those are good shotguns. It could be the firing ignitor. Two solenoids control the signal to the element. If thay stick it keeps the element on too long or too shot. Take it down to test at Sears. Good luck - Doug
Posted on Dec 09, 2009
Gas dryer checked ignitor, thermal fuse and flame all had continuity still ignitor will not glow or heat
Will try to help you checked the igniter you say good if good does it glow if so clamp on one wire and take an amp draw while heating I like to see a minimum of 3 amps if glowing and 3 and above change the coils on the gas valve very cheap, now if not glowing and good ignitor the fun begins power comes out of the heat relay on the control board passes thru the thermal fuse then thermal cut off then hi limit then the flame sensor while also feeding the gas coils the neutral is supplied thru the centrifugal switch on the tumbler motor if the dryer stays running the centrifugal switch is good and you have a neutral bad flame sensor very rare since I am not there check the thermal cut off once blown it does not reset has to be replaced if all the fused I mentioned check good then check the heat relay on the board black and red wire stick meter ends in both off should read 120 volt when machine turned on should hear it click and meter should read 0 volts the boards seldom go bad but I have replaced a few in 5 years I am leaning more towards an open thermal cutoff
Feb 20, 2015 | Whirlpool Dryers
White knight 427 not heating
Heating element is probably burned out. Or the thermal fuse / cutoff. I would check the fuse first as the heating element has 2 independent heating coils and usually both won't burn out at the same time. It would be best to have a meter tester. I am in Lake Worth, Fla. I travel within a 40 mile radius How to Replace White Knight Tumble Dryer Heating Element Heater...
Sep 12, 2014 | Dryers
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a whirlpool dryer that won't heat. I removed the heating element and there were no breaks in the coils. I had the thermal cutoff tested and it was bad so I replaced it as well as the part
check the little 1"long x 1/4" wide white plastic fuse located on the dryer blower housing in the lower rear area,its held in place with 1 hex head screw,if its open dryer wont heat
Mar 11, 2012 | Whirlpool Dryers
I have a kenmore gas dryer, the drum turns but no heat, I replaced the radiant sensor and the control thermostat but still no heat?
here is a partial list of componets that could cause the dryer to not heat
Ignitor
control t-stat
high limit t-stat
gas valve coils
thermal cutoff
thermal fuse
flame sensor
electronic control/or timer depending on your exact model
cycling t-stat
motor
Jul 23, 2011 | Dryers
Dryer is not heating up, but will tumble
Hello there and thank you for choosing fixya
This is a fairly common issue with dryers
There are only a few items that will make a dryer not heat Depending on your model
The first is the thermal fuse
To be fair, this failure's usually not the thermal fuse's fault, but the real cause lies in a partially (or completely) clogged dryer vent system. In those cases, the thermal fuse is just doing the job it was designed for.
Thermal fuses, or thermal cutoffs, are small electrical temperature sensitive 'switches' designed to interrupt electrical current flow when heated to their specific rated 'trip' temperature.
Unlike a thermostat, which automatically resets itself when the temperature drops, thermal fuses are more like their cousins, electrical fuses, another single-use type device that can't be reset and must be replaced when it fails or is triggered.
In addition to their legally mandated application in modern clothes dryers (since the 1980's), thermal fuses are used as safety devices in other heat-producing appliances like coffee makers and hair dryers. They disconnect the flow of current to the heating element in case of malfunction (such as a defective thermostat or clogged dryer vent) that allows the temperature to rise to dangerous levels, possibly starting a fire.looks lke thistbirdfan1_81.jpg
and the last thisn is the heating element it'self
most of them look similatr to this one below but once again yours may be differenttbirdfan1_82.jpg
May 06, 2011 | Dryers
Dryer tumbles, no heat, thermo fuse has been changed. Can it be the cycling thermostat or the heating element?
If you have changed the thermal fuse you may have a defective thermal cutoff (located at the top of the heater housing in the back). The thermal cutoff will come with the high limit thermostat located at the bottom of the heater and you should change both parts if the thermal cutoff is bad.
You can take both of the parts (the heater and the thermal cutoff) to a parts supplier to have them checked for continuity (they should both read "closed" if they are good).
Good luck to you!
Oct 07, 2010 | Whirlpool WED5300S Electric Dryer
Can't control heat setting
Either your dryer vent is clogged, the blower wheel is striped out and not turning or the internal bias thermostat you bought is bad. These are the only things that can make the dryer over heat.
Please rate solution.
Sep 04, 2009 | Whirlpool Dryers
Gorenje Tumble Dryer WT 881 - how do I replace heating element fuse?
I would start with house fuses or breakers, if breakers then turn breakers off then back on several times then try the dryer again. Then I would check the cord where it connects to the dryer. After that I would start checking elements, thermal overloads/cutoffs, etc. most dryers have several normally closed t'stat/ overloads and a thermal fuse. If the thermal fuse or cutoff is blown you also need to check your venting. these safety fuses are not resettable and are usually an indication that the vent may be clogged and/or obstructed.
Nov 04, 2008 | Dryers
Dryers Logo
69 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
