Question about Dryers
My Kenmore dryer 400 series...doesn`t work properly....The gas is not ignite all, the times....
    Scholar:
  • 135 Answers
Try this web site
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Hope this helps
Posted on Dec 10, 2009
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 05, 2011 | Kenmore Dryers
I have a Kenmore 400 series gas dryer it works except no heat when I look for a ignitor flame I don't see anything. What do I do?
In most gas appliances it is common problem and It could be caused by defective igniters or main valve or control board or dirty nozzle or gas line issue .Use step by step troubleshooting procedure
For Best safety reason and prevent dangerous consequences and prevent of any hazards of fire and complication with home insurance companies and most important personal safety reason when it comes any gas or propane appliance repair it is best practice to contact insured and bonded local expert gas appliances service centre for best safety reason
Dec 12, 2010 | Kenmore 400 6943 Dryer
I have a Kenmore 400 series gas dryer that's four years old. Recently, it has been giving me problems heating up. Half the time it heats up, the other half it doesn't and when I open the door I can smell...
In most gas appliances it could be caused by defective igniters or main valve or control board or dirty nozzle or gas line issue .Use step by step troubleshooting procedure
Nov 28, 2010 | Kenmore 400 6943 Dryer
We have a Kenmore 400 series dryer. It heats up but does not stay heated. We have already replaced the ignitor and all the fuses show current... Any ideas?
In most gas appliances it could be caused by defective igniters or main valve or control board or dirty nozzle or gas line issue .Use step by step troubleshooting procedure and clean vent
Nov 23, 2010 | Kenmore 400 6943 Dryer
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
My Kenmore 90 series dryer's pilot light is out. What can I do?
Modern Gas dryers do not have a pilot light. You CANNOT re-light them. They use a glow-bar or spark type igniter to ignite a flame. If you are having problems with ignition, the first thing to check would be if your igniter is working or not. Here's some useful information about igniters you should know and understand:
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
An easy way to determine if you may have an igniter problem is to check for a glow or listen for a clicking noise. The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad.
Please provide an accurate model number and I can assist you further. If you have questions, please post back and let me know. I hope you find this information helpful.
Feb 24, 2009 | Kenmore 63942 Dryer
Kenmore 400 series electrical dryer
I have a 400 series kenmore dryer that just quit running after 10 min. into cycle. breaker in house checked and is ok but no power to dryer. what could the problem be
Oct 18, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
Marvin
Marvin
