Question about Sony Playstation 3 (PS3) Console
When either putting the hdmi lead or the normal leads into tv I get the signal no signal I have now tried 3 tvs and the same thing comes on the screen please advice
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Might be because the TV does not support HDMI. try with regular cords if that works, then the HDMI cables need to be replaced.
Posted on Dec 10, 2009
I have a goodmans TV is having issues, sky box works fine through the hdmi but, ps3 no display or sound through the same port, my ps4 gets pic but no sound, both consoles have been tested on other tvs
1.Put your PS3 on standby.
2. Unplug the power lead.
3. Connect HDMI cable to HDMI out on PS3 and HDMI in on TV
4. Connect PS3 so that the red standby light is showing
5. Hold down the On/Off button until you hear a second beep. The PS3 will try and detect the display output settings on your monitor.
Dec 02, 2015 | PS4 Video Game Consoles & Games
Connect tv to iPad NO SIGNAL problem
Check the input or source on the TV to make sure it is on the correct input for the ipad.....
Apr 30, 2014 | LG 19LS4R 19" MULTISYSTEM LCD TV...
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
Sep 26, 2017 | Televison & Video
I have just brought ps3 and when i plug the leads into the tv ie red white and yellow leads i can not find the channel on my tv i have tried other tvs and same thing so i done away with the lead and just...
Hi, try not using the hdmi lead and plug the other lead back into the ps3 the normal av lead with the 3 color wires, now plug it into your telly now switch the ps3 on at the back so the red light is on at the front, now hold down the one button and it will bleep once then bleep twice and keep holding it down till it switches back off
so basically you switch it on at the back then press and hold down the on button until the ps3 turns itself back off, now what this does is reset the video mode so its not set to hdmi settings, now press the on button again and wait for it to come on if you still dont have picture on the telly make sure the video lead is fitted correctly and then get the telly remote and find one of the following buttons
av
source
input
or a rectangle with an arrow facing to the right.
once you have found this button make sure the ps3 is on and then press this button on the tv remote, you may need to press it more than once depending on how many inputs the telly has on it.
now when you press the button on the tv remote press it once then wait 5 sec before pressing it again just to give it chance to pick the signal up.
hopefully now you have the ps3 working through the normal av lead
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
"no signal" showing on tv screen
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 29, 2010 | Sony Playstation 3 (PS3) Console
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Green dot's and pixelation via hdmi
its the ps3 u have to send it back to sony! the green dots will get worse and start to freeze up ur system i had the same problem last month!
Jan 03, 2008 | Sony Playstation 3 (PS3) Console
Watching digital tv using a Panasonic DMR-EZ47VEB
PLEASE NOTE THIS INFORMATION COVERS PROBLEMS FOR ALL DEVICES CONNECTED UP BY STUPID scart LEADS. I HOPE IT HELPS EVERYONE.
This is a common problem, the problem is caused by the fact your device is connected to the TV via a scart lead. The way it works is this: If you press the AV button on your TV remote your TV will turn over to the first scart channel. If you actively do something on the device connected via scart in this case the dvd player, (this includes things like playing a DVD or Video, or going into a menu), the device sends a signal down pin 8 of the scart lead and turns the TV over automatically to the AV channel, BUT as soon as you come out of the menu or stop the DVD/Video the signal stops and the TV will revert back to the channel it was on.
So you have 3 choices......maybe 4...
1. press the AV button on your TV remote directly.
2. Buy yourself and HDMI lead IF your TV supports it (note: you will have to select the HDMI channel on your TV remote because the auto thing is only on scart leads).
3. ONLY DO THIS IF YOU HAVE A SPARE LEAD look up a diagram of a scart lead on Google so you can find pin 8 and cut it out with a pair of wire cutters. YOU will have to still press the AV button on your TV remote to go to the channel though,
4. Connect your TV and DVD with an aerial lead and tune channel 6 on your TV into the DVD player. ps then disconnect the scart lead.
(Go for choice number one!)
Oct 14, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sony Playstation 3 (PS3) Console Logo
83 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
john o grady
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
