Question about Homelite Consumer Products Backpack Blower/Vac, Carb
I have a Homelite UT08580 26cc MightyLite Backpack Blower. Since new it has run poorly if at all when the choke is in the run position. Normally I have to use it when in the 1/2 choke position. It has caps on the carb mixture adustments, otherwise I would be adjusting the high speed mixture richer. What can I do?
  • Dave Lloyd Dec 15, 2009
    Put on my bifocals and discovered the mixture adjust screws weren't capped, just round with a little notch in them. I cut a piece of 1/4" tube, put over the adjust and gave both the high and low speed a half turn. For the first time since new out of the box it runs like it should.
    President:
  • 1,627 Answers
If you have'nt yet you should put a kit in the carborater,if that does'nt fix it{should} then you may have a plugged muffler,.if you can't get rid of exhaust you can't be reved up.
Posted on Dec 09, 2009
I have the MightyLite 26bv....will only run at half choke. When turn knob to run, it dies. Does not reach full power ever.
The parts inside the carburetor need to be replaced (gasket and diaphragm kit) and/or the L and H screws need to be adjusted on the carb. Try grasping and turning the L mixture screw on the carburetor (one closest to engine) about 1/8 to 1/4 of a turn counterclockwise.
Jul 01, 2011 | Homelite Consumer Products MightyLite...
I have the homelite mighty lite backpack blower. i don't have a problem starting it. The problem is when i turn the choke to 1/2 and then full running position, i strap it on my back and then this is where...
you have a dirty or blocked carb jets strip down the carb and clean out the running jet
dont poke wire into any of the jets to clean them this will distroy them!!! use car cleaner and cmprest air if you can,,good luck mike
Nov 04, 2010 | Homelite Consumer Products Backpack...
I can start the lef blower in choke mode but can not move it to run mode with out the blower stopping.
Carb needs adjusting. Turn low side out half turn. If that doesn't do it, time to rebuild or replace carb.
Aug 10, 2010 | Homelite Consumer Products MightyLite...
Wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
May 15, 2010 | Homelite Consumer Products MightyLite...
My homelite might lite 26b will run in the choke position but cuts off in the run position. I have drained the gas and put in fresh gas, new plug and opened the carburetor and cleaned it.
if it seems low on power,remove the muffler and clean out all carbon build-up,if it has power as in full throttle,then the carb is still dirty and needs to be rebuilt
Mar 12, 2010 | Homelite Consumer Products MightyLite...
My Homelite mightylite blower vac starts but won't stay on unless choke is closed down the unit is only one season old. The unit is supposed to be in warranty for two years but Homelite said not the...
The unit is under warranty. The person you talked to must be new. Find a warranty service center in your area. Take your receipt with you and they should be able to take care of it for you.
Good Day
Dec 13, 2009 | Homelite 'Yard Broom' Leaf Blower
My Homelite 26b will run at full choke but will not run at half choke or in the run position. I looked at carb and all gaskets. everything looks good.
make sure your fuel mixture is correct also check t your air cleaner it will not run right without it or if it extremly dirty
Oct 25, 2009 | Homelite Consumer Products MightyLite...
I have a homelite model uto8550 26cc mighty blower/vac. On initial startup it runs at half choke then stalls when i turn it to run. Any suggestions?
1. check fuel filter in gas tank (for clogged condition).
2. Check carb jet for dirt (squirt carb cleaner in jet and fuel inlet
Summary: your carb is not getting enough fuel to mix properly with constant air flow. Therefore, fuel supply needs to be cleaned... then you will run happy!!
-Jim
Oct 23, 2009 | Homelite Consumer Products MightyLite...
Mightylite 26 leaf blower
have you tried changing the air filter and spark plug?
Nov 20, 2008 | Homelite Consumer Products MightyLite...
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
1,285 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
