Question about Euro-Pro 9105 Computerized Sewing Machine
I love my sewing machine, but am having some problems with it recently. It's not grabbing the bobbin for some reason just goes right over it. What can I do?
SOURCE:
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
SOURCE: Sewing Machine
check if you are using the original bobbin... There are some similar bobbins but they are not the same...
Posted on Sep 05, 2007
  • 12 Answers
SOURCE: Bobbin thread breaks
Things to check for thread breakage (top or bottom)
1. Good thread in the machine - not hand thread, cheap thread, quilting thread.
2. A burr on the hook - a small nick on the hook can grab and tear threads, however this usually causes the top thread to tear, not the bottom
3. Make sure a new needle is in the machine - one made for the material you are sewing
4. The bobbin must be installed to rotate in the correct direction in your bobbin case
5. And I'll say it anyway - tensions - the primary cause of thread breaking - Remember, there are TWO tensions in a sewing machine, top and bottom. Also, the thread you see on the bottom of the stitch is the top thread, and vice-versa.
Posted on Dec 04, 2007
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: bobbin case problems with machine,
my bottom bobbom wont catch how do i fix the timeing or restart settings?
Posted on May 08, 2008
My Singer Futura II, model 920 won't sew. The top thread is threaded correctly, new needle, tension set correctly and the bobbin won't wind with thread. I have had this machine since the early 1970
IF IT WON'T SEW AND THE BOBBIN WON'T TURN FREELY THEN THE SIZE OF THE BOBBIN IS WRONG. MAKE SURE IT IS THE RIGHT HEIGHT AND WIDTH. THE RIGHT TENSION OF THE BOBBIN HAS TO BE RIGHT OR IT WON'T SEW RIGHT EITHER. IF THE BOBBIN DOESN'T WIND WHEN YOU ATTEMPTING TO REFILL IT THEN YOU HAVE A BOBBIN THAT IS THE WRONG HEIGHT.
Sep 07, 2014 | Singer Sewing Machines
Cannot form any sort of stitch on my singer 237
is the needle turned the right way?--flat side goes to the back of the machine
Feb 10, 2012 | Singer Sewing Machines
I got a White 3032 sewing machine for Christmas last year and I couldn't get the bobbin to thread, I exchanged it and the new one does the same thing. Why won't it pick up the bobbin thread?
Have you got the bobbin in the right way ? Is the bobbin thread in tension? Turn flywheel towards you while holding the tail of the top thread, turn through one rotation so needle goes down into rotary hook then up again to top position. Now pull thread tail and bobbin thread should come up through needle plate in a loop. Draw the rest of bobbin tail up to top. Can you get a lesson from sm retailer? They should give you a basic demo at least. Consider buying a reference book on the sewing machine such as singer sewing machine book or similar. Sewing is a skill best learnt in classes if you can.
Apr 16, 2011 | White Sewing White 3032
The thread clicks when it goes around the bobbin and I have to stop sewing as it makes a big knot on the back of the fabric. I have cleaned out the bobbin case but it is still not sewing properly. It was...
Hello Supernana.
Check to see if you have your bobbin in upside down. If your machine requires it to unspool from one side having it spool from the other side (counter clockwise vs clockwise) can cause you problems like this. Your manual should tell the correct direction. My machine (Brother) for instance requires that the thread to pull counter clockwise direction.
Sylvia
Mar 17, 2011 | Elna Quilter's Dream 6003Q
When attempting to sew the bottom of the material stitches are all bunched up. Could it be the bobbin?
It could be the bobbin if you put it in the bobbincase upside down and its turning the wrong way. When its in the bobbincase and you pull the thread while looking at the bobbin, the bobbin should turn clockwise. If its turning counter clockwise flip the bobbin over.
It could just be the top isn't threaded right also.
Or maybe there is a burr on the hook that grabs the thread as it goes around. The burr would catch the thread and foul everything up.
There are a few reasons for what you described.
Rick
Sep 03, 2010 | Sewing Machines
Hello I own a lovely old singer sewing machine,
Hi Mary! These old Singers are such wonderful machines! I'm always glad to hear from someone who loves them and uses them--they will last practically forever with very little ever going wrong.
Sounds like your upper tension is a little loose. I like to use different color threads on top and in the bobbin, to make the stitches easier to see. Also, are you using size 12 needles and 50 wt thread when you're adjusting the tension? Sometimes having a larger (or smaller) needle and/or thread can throw the tension off just a bit. Also, make sure the pressure foot is up when you're threading the machine but down when you adjust the tension and that you only adjust the tension in tiny increments.
You may need to adjust the bobbin tension--but that very seldom needs to be adjusted.
It's also possible that there's a bit of thread or lint caught in the tension disks or in the bobbin area.
Please let me know if these suggestions work.
Happy Sewing!
Robbie
May 12, 2010 | Singer 132QRFB Mechanical Sewing Machine
Kenmore 158.19141 help!!
Hello. The 158.19141 is probably the best Kenmore sewing machine around. I use two of this same model in my sewing/alterations business and they have been totally dependable. (I also have 3 vintage Kenmore computerized machines) but the 158.19141 is my favorite model. The problem sounds as though there is dust/dirt/lint in some of the parts in the machine. Take off the feedplate, vacuum and or use a lint brush to loosen any threads and lint. Take out the bobbin case and bobbin: inspect for lint and dust. Take out the bobbin shuttle (which tends to make the threads bunch if it has lint build up). Clean or vacuum, PUT A DROP OF OIL ON THE CENTER PIN, and replace.
Oil the machine regularly. If it has sat around for months without use, it may tend to get sluggish.
Make sure your feeddogs are UP. Use an appropriate size needle for your fabric and make sure it is set properly. The flat side of the needle has to be facing to the north of the machine; and make sure the needle is inserted entirely up and tightly into the needlebar.
Threading the machine properly and inserting the bobbin correctly is usually the answer to most frustrations with a machine. Good luck...and lucky you to have the Kenmore 158.1914 model.
Sep 24, 2008 | Kenmore 744-08BH Mechanical Sewing Machine
Winding the bobbin?
Most of the entry level machines will have either a clutch knob or an automatic release when the bobbin winder mechanizm is engaged (put a bobbin on and more the unit to you right). If it does not disengage the clutch automaticly then either loosen the clutch wheel by turing or pulling. Sometines you have to grab the whole clutch wheel to disenage the mechanism to free wheel while winding the bobbin. Now press you foot control to wind the bobbin.
SewTech
Apr 21, 2008 | Janome Mini Compact
Janome 8080 computerized sewing machine
Is the bobbin the correct size? if you have spare bobbins do they all have the same problem?
Oct 25, 2006 | Janome 8080 Computerized Sewing Machine
Euro-Pro 9105 Computerized Sewing Machine Logo
14 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
