Question about Dishwashers
Amana Dishwasher dishwasher will fill with water, then will proceed to just hum through the wash cycle, no water is pumping through the turning blades. It will stay humming until you turn it off by hand ( dial will stop mid way through cycle)
  • gfriesen May 02, 2008
    My dishwasher also fills and then does not spray. I took apart the assembly inside the tube down to where I could see the pump in action. The pump impeller spins for a little bit and then comes to a stop. Even when spinning, you can put your finger on it and stop it. Like it's not really connected to the motor.
  • 1,314 Answers
Sounds like something is jamming your wash inpeller start at the washer arm and go down till you get to the wash impeller and see whats sticking it like broken glass small peice of bone toothpick etc
Posted on Jan 19, 2008
My Whirlpool dishwasher GU2400XTP fills with water and pumps out properly but does not wash. The pump hums during wash cycle
is there food particles clogging the water intake for the pump or it could be that the motor is seized from bad seals if that is the case then you may want to see if you can get a new pump motor
Feb 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
My carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher keeps stoping
Favorite for bosch is the water inlet modual which monitors the water flow in could be faulty, If incorrect pulses take place the motor wont proceed. Otherwise listen for a hum after water stops filling. If there is a hum, the main wash pump is jambed and has to be sorted out.
Jun 08, 2008 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
May 04, 2007 | Maytag 24 in. MDB7751AWS Stainless Steel...
Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
Apr 02, 2007 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwashers Logo
294 people viewed this question
Top Dishwashers Experts
