Question about Kenmore Refrigerators
Bottom freezer model, fridge temp is @ 24 degrees, but it is set to 46 degrees.
  • 478 Answers
Some times the flap that controles the temp inside the fridge gets stuck or sometimes (hate to say this) parts and not installed properly or not at all I have found this to be true from alot of hhgregg stores they seem to buy defects and then replace the missing part
Posted on Dec 10, 2009
My Viking professional refrigerator is stuck on 46 degrees refrigerator/ 6 degrees freezer. None of the buttons work. Is there a reset button?
press display on or (activate control) button first you should then be able to choose fridge or freezer and change set temp
after set will read actual temp 46 is a little high sounds like you have service issue
Jun 27, 2017 | Viking Refrigerators
Kenmore side by side refrigerator model 596.50009100 not cooling.
I would make sure they fan on the bottom that cools the condenser is turning easy way to test is. Put a fan in front of the fridge blowing under it if it starts cooling that is now working right
Nov 12, 2013 | Refrigerators
Recommended temp settings for freezer and fridge
The ideal freezer temperature is 0 to 5 degrees and the fridge section from 36 to 40 degrees. However, you will get more accurate responses if you leave the model number of your exact unit.
Jul 15, 2013 | Computers & Internet
Whirlpool french door refrigerator
What is your model number? With the model number I can look up the components that may be causing this problem. Example would be a defective thermister or thermostat control. Thanks Sea Breeze
Apr 24, 2013 | Refrigerators
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
Compressor overheated and shut down.
Pleas put setting in the middle and give it 24 hrs and check temps
freezer would be good at 0 to 10 f
I thing you have the damper door closed.
May 24, 2010 | Whirlpool GS6NBEXR Side by Side...
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
May 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
