Question about Equator EZ 1500 Front Load Washer / Dryer
Replaced motor and control board everything else tests good any ideas.
  • 478 Answers
Curcut breaker, timer, safety switch on door
Posted on Dec 09, 2009
Treadmill SLT-02 flashs E1 and wont go. Everything else has been checked out and has a new belt and otherwise in good working order. How do I fix it
Please test the motor with the thermic switch inside of motor, for open or close, and repair. 2) Test the main motor with BATTERYR motor cicle 12Vdc, and see if the motor is running.
3) If everything is o.k the Controller motor board is faulty. replace LED Blink Patterns on the Control Board Treadmill
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 21, 2017 | Exercise & Fitness
Error code 660 & 595
test the output control board motor, if there are NOT voltage for to input voltage terminal motor, the control board is faulty, replace.
2) If there are voltage terminal motor, the motor need to test, take out the belt, and try again if the motor RUN the problem is deck belt board, LubE IT. see my personal TIPS for motor.
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
The incline don't work
1) LUBE the shaft from Incline Motor very important
2) Tight the connector that connect in the controller board motor , take the cover where the main motor is. and look for the connector.
3) Looke for some loose wires and tight.
4) Measure 110Vac in Elevation or Down, if does not have see if there are Limit swicht and test it, and replace if Do not have l.switch y use Capacitor test it if there faulty, replace.
5) If everything is Good, test the Incline motor, and see if ok, applying 110vac direclty, disconnecting all wires from the controller board motor.
If not Work, replace.
Blessing.
Oct 23, 2017 | Exercise & Fitness
I have a Nordic track commercial1500 and the belt motor will not run. Everything else works fine. The fuse is good on the board.
1) see if the belt is tight or loose, repair or replace the belt
2) test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulyt, replace see the b.diagram attached.
Jan 09, 2013 | Nordic Track NordicTrack Commercial 1500...
Coleman-blower motor contiuesly on even when t-stat is not calling for heat? Suspect relay on control board stuck closed?
Hello, the relay on the intergrated control board is stuck. Unfortunatly the relay is part of the board, so the entire control board must be replaced.
Dec 02, 2012 | Heating & Cooling
Just received my merit 715T plus, assembled it, plugged it in. the console display comes on, but then nothing happens. i press the buttons and nothing happens. the safety key is in, and i opened the...
Please Reset the C. breaker or see the fuse if has.
2) Please RETIGHT the connector coming from the Controller board Motor from the hood, UPPER lever where the console connector is there very well, See if there are some wires loose, or desolder, and cleaned very well.
3) If everything is right, TEST the 8-12Vdc to the Console Board. if there the Console Board is Faulty.
If there are NOT the Controller board is Faulty, and Replace, since some IGTBs is faulty.
Blessing.
Nov 25, 2017 | Merit Fitness 715T Treadmill
Everything works. but the treadmill motor won't start when I press the on button.
If you press start and the belt will not turn, but your incline is working, the time is counting and the speed #'s change. The problem would most likely be the lower control board. It could also be your motor. Have a professional test the motor with a DC voltage source. If it tests OK the problem is almost certainly the control board. Depending on the brand, some control boards have a fuse. Have the fuse checked and if it is bad replace it and try starting the treadmill again before you buy a new control board.
Nov 23, 2010 | Proform CrossTrainer Treadmill
I have a Horizon elite 507 treadmill, everything works except the main motor which drives the treadmill itself, is there a simple answer such as a fuse or trip switch i can change/reset?
Unplug your treadmill and remove motor shroud ,locate Motor control board their a series of LEDs . Now without getting on treadmill hit start look down and you should a light starting to flicker this is your PWM signal, t the upper console sends a signal to the lower board and instructs the motor to start. This tells me that the upper board and cable are functioning properly and our problem is either the board or motor.
DC motors can be easily tested in a number of ways. Many times a motor is replaced only to find another problem exists so be sure to test the motor if you think it is a problem. Methods to test a motor: 1) Cordless drill battery- get a fully-charged, 18 volt (preferred) cordless drill battery and on most treadmills connect the red and black motor leads to the battery (some have different colors but if you have two wires and get it hooked up backwards, the motor will just run backwards and won’t be harmed). If good, the motor should operate at about 1 MPH. 2) Car battery- these are 12VDC high amp batteries so the motor will turn slowly but you can walk on the belt. Always be careful with battery acid on these things so we don’t recommend bringing them in the house…take the treadmill to the battery.
If the motor test good then all fingers point to the Motor Control Board replace the board. When was the last time lubricated the running deck?
Answer: Never ! Then I suggest you purchase lubricant and apply it on the deck about 75% to 85% of the problems are belt and deck related.
May 23, 2010 | Horizon Exercise & Fitness
My Vision Fitness t8500 treadmill's deck just stopped working. It makes no noise when i turn it on. all other functions (elevations & programs) work fine. any troubleshooting ideas?
I had the same problem. I even ordered a $300 controller board. The new board didn't work either. That's when I started checking voltages from the control board to the motor. That was good. Lastly I checked the brushes. Almost nothing left. . . The motor started working again after I put everything back together. I need to order new brushes and return that contoller board.
Dec 28, 2009 | Exercise & Fitness
Equator EZ 1500 Front Load Washer / Dryer Logo
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
