I have an old Hermes 3000. I was in the middle of typing away and the machine was working perfectly. Then all of sudden the carriage will no long stop. It just slides directly to the right margin and stops there but can't be held anywhere else, literally making it impossible to type. I've looked through my owner's manual and it says nothing about this. Please help!
    Champion:
  • 204 Answers
It might be that you tab key is engaged which would do this. also try gently moving the carriage to a point, pressing the space bar and then releasing the carriage. It might be the escapement..
Hope this works!
Posted on Dec 19, 2009
SOURCE:
I have just bought a Hermes 3000 typewriter. I have set the margins at 10 and 60 but the carriage keeps sticking at 40. I have cleared all the tabs. Can anybody help please?
OLD but great machine, check the rails that the carriage
comes across, also some had a lock that locked the carriage in a set position for shipping, something is stopping the movement.
Oct 08, 2018 | The Office Equipment & Supplies
I recently bought a 1964 Hermes Ambassador typewriter. The typewriter is in very good shape, -but the carriage is slid all the to right (as if ready to start typing)and will not move. It acts as if it is...
I worked on typewriters for many years. If the unit has been sitting for years, it is in need of a good cleaning when you depress a key, it activate a mechanism that rotates a pawl on a toothed rack under The carriage. Plus there is a final stop that stops the carriage from going to far too the right. Flip the unit up and push the carriage lightly and watch the mechanisms spray light lube and keep moving the mechanism it should loosen up. Depress space bar and gently pull the carriage to the left. You may also have lost the tension cord. That's a spring assisted coil that pulls the carriage. You have an old unit there. It was great in it's time.
Feb 08, 2015 | Office Equipment & Supplies
Typewriter carriage
The typewriter needs the escapement adjusted, or you have a bind in the escapement, and it probably needs a good cleaning and oiling. This usually done by a pro.
Oct 07, 2013 | Office Equipment & Supplies
I have a Hermes 3000 typewriter. Once I set the left margin, it's not sitting there. It moves fast to the right margin. I am not able to type a single word because of this. Is the mainspring is bad? ...
The mainspring is not bad or the carriage would not move that way. It sounds like and escapement problem either from the carriage release sticking, the escapement itself needing adj. which you probably cannot do, the escapement rack is bent or maladjusted, or the tab function is sticking or maladjusted. Check the carriage release levers to see if they are sticking. Also make sure the tab function is knocking off so the carriage is not in constant tab mode. Hope this helps.
Oct 07, 2013 | Royal Office Equipment & Supplies
My old manual Olympia typewriter always stops in the middle of the carriage when typing. If I hit the shift key it will move forward and I can continue to type. What is the mechanism that makes it s
The carriage is touching the cavers it need the flat rubber washers that are between the case and the frame look at the bottom of the typewriter remove the screw slip in a new washer and replace the screw do the same on the other side
May 21, 2012 | Olympia Manual Typewriter
Where can i get a manual for my smith-corona typewriter?
Can you give us any help in identifying the machine? Is it manual or electric, for example?
There's a downloadable and printable manual for the Smith-Corona Standard Portable here.
Bear in mind that if this is an old typewriter then there is a very good chance that no one has bothered to rewrite the manual since the invention of the internet. In such cases the best you can expect is a scan of an old paper manual.
Mar 29, 2012 | Smith Corona Office Equipment & Supplies
Hermes 3000 carriage is "locked."
I think there's a lock there in the spacing. Mine can be locked by pulling the spacing lever far upward. Just set your spacing and I think it will unlock.
Apr 18, 2011 | Office Equipment & Supplies
Hermes 3000 tab stuck in middle.
After you press the margin release key, space to the desired R. margin location, press the R. MAR key.
DickyO
Jul 10, 2010 | Office Equipment & Supplies
Xtpe 2.1 petrol manual 2003 cuts out suddenly for
Check for leaking manifold if problem occurs around 3000 rev point
Feb 16, 2010 | 2003 Jaguar X-Type
Cartridge jammed and sccaning error
When you open the clamshell does the ink carriage slide back and forth with jamming?
If not then try getting some silicone grease and apply a very very thin line of it on the rail.
If it does then try making a copy, in the middle of the process, before the error, open it up and see if the ink carriage has even moved from "Home" position.
You might have a belt issue and this could be one of many things, stripped plastic gear, streatched belt...
Jun 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
226 people viewed this question
k24674
Marvin
Marvin
