Question about Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper
Beeper sounds as soon asyou press forward or reverse will not drive brake engaged tthis is the same sound if you tried to move with the brake disengaged.
    Sergeant:
  • 313 Answers
This could be the break micro switch or the wiring in the motor brake loom. check all connections in this area. You do not say what make or model this is ? !
Posted on Aug 09, 2010
My mower stopped moving forward and reverse. engine starts easy but hydrastatic pedal does not engage
check pedal connection rod or cable -- check under unit for drive belt problems ---look at axle override lever or rod not engaged --park brake engaged--if all look good possible failure of axle unit
Jun 03, 2017 | Garden
My A160 Benz semi auto having problem with trnsmission can not engage forword or reverse.
when a transmission is in drive it will always try to drive. even with the foot on the brake it is still trying to drive.
Run the fault codes for the transmission as I suspect there will be a problem in the torque converter clutch/ servo/solenoid .
Jan 03, 2015 | Cars & Trucks
Why would a vehicle in reverse move forward
The question is a little vague but I think I know what your referring to. All modern automatic transmissions have torque converters. This is the device that connects the engine to the transmission. All vehicle manufacturers like the trans to be nice and smooth shifting. That's great but it does come with some minor drawbacks. If you are facing slightly down hill and you put your car in reverse but do not step on the gas slightly I can guarantee that you will indeed roll forward. You can eliminate that issue by holding your left foot on the brake while you shift into reverse. Then, as soon as you feel the trans engage, gently depress the gas pedal with your right foot and it will eliminate that forward roll problem.
Sep 25, 2014 | Cars & Trucks
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Bought a 1990 Bronco II from one of my troops and somehow he drove it over here. It's a manual transmission as well. But once I put it in first gear, it feels like something is stopping it going forward....
It sounds like you may have a brake caliper sticking (if the issue is really coming from the front). Does it pull in one direction? One way to check is to jack the front end up and try to spin each tire by hand. They should turn relatively freely. Another possibility, and more likely from your description, is that the rear emergency / parking brake may be frozen. Drum brakes, by nature, do a better job of holding the vehicle from rolling forward. If your emergency / parking brake is engaged, either frozen or inadvertently left on, I would expect the symptoms you describe- moving in reverse, but not forward. You can check this the same way- jack up the rear end of the vehicle, put it in neutral, and try spinning the rear tires by hand.
Assuming your vehicle is a 4x4, a less likely scenario is that something's gone awry in the transfer case, front differential, axles, hubs.
Good luck.
Feb 01, 2011 | 1990 Ford Bronco II
Could frozen e brakes cause car not to go forward, car moves easy in reverse
No. An emergency brake on the 86 camaro engages the pads against the rotor and the vehicle would not move either in reverse or forward. It sounds like you have a gear problem in the transmission that could be related to either solenoid or actual gear wear. Assuming the vehicle is being MOVED as you say while the engine is running.. thus providing the energy to move it.. Going in reverse has the solenoid engaged one way, drive the other way. Solenoid sounds damaged at this point. Unfortunately this probably will require a transmission rebuild.
Jun 06, 2010 | 1986 Chevrolet Camaro
Beeper sounds as you press forward or reverse no drive. this is the same sound you hear if the brake had been disengaged batteries have been renewed and all connections checked.
hi, it a general error - warning sound, if the wheelchair has got wet then I suggust you carefully go all over the wheelchair looking for damp connectors , simply re-inserting them should do the trick,
Make sure all connectors are tight and make sure the freewheel switch is working correctly, that can stick.
Regards
GeWiz.
Dec 11, 2009 | Electric Mobility Shoprider Electric Power...
AUDI A4 AUTOMATIC SLOW TO ENGAGE FORWARD GEARS ,REVERSE ENGAGES INSTANTLEY BUT TO MOVE FORWARD I NOW SELECT DRIVE FOR AROUND THREE MINUTES THEN MOVE OFF SLOWLEY,THEN ALL GOES WELL
Not overly familiar with Audis but it sounds like either a.) you have an electronic tranny that has a serious bug or b.) there's a problem in the computer of the car itself. What is sounds like is the car is taking a long time to "understand" that you're telling it to move forward. How new is the car? When you push on the gas before the three minutes, what happens?
Oct 21, 2008 | Audi A4 Cars & Trucks
Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper Logo
177 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
