Question about Metrologic Instruments 9520 Voyager
Metrologic 9520 help...Please
Power outage caused my scanners to not work...The manual is very confusing to me...As of now it only scans short bar codes...Please Help...I own a retail store if that helps on where to look in the manual, in order to reprogram the scanners to read longer bar codes...Let me know if this might be a communication error with cash register and scanner?
Thanks Very much. Dennis
Is it 13 digit barcodes you are trying to scan?
Also, does the cable go straight into your till (straight cable) or is it connected to you keyboard via a wedge?
Posted on Jan 21, 2008
Metrologic ms9520 not scanning UPC's
Hello.
The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code.
You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.
http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40
Hope this helps!
Dec 01, 2011 | Metrologic Instruments Voyager MS9520...
Barcode font problem
Try going to the manual and scanning the setup code for accepting a the I2of5 code.
May 21, 2010 | Metrologic Instruments 9520 Voyager
Scanner stopped working. Only one light is on on
you will probably have to get another scanner or have the lights replaced
Apr 08, 2010 | Metrologic Instruments 9520 Voyager
We recently received another 9520 from Honeywell to replace a faulty one. For the non-tekkie, how do I configure it for use with library scanning for books?
Bar Codes The MS7120 can be configured by scanning the bar codes located in the MetroSelect® Single-Line Configuration Guide. This manual is available for download at http://www.honeywellaidc.com/site.aspx/na/en/product_center/product_support/?category=5&product=297
Please let me know if you need further assistance
Kim Ganoe 800.933.2839 x251.
Mar 23, 2010 | Microsoft Metrologic MS9520 Voyager...
Hooked scanner up to new computer. Reads bar code
It sounds like you are connecting to a serial port and you are trying to scan into a program that needs keyboard data. Download the "Softwedge" program from the Metrologic website.
Mar 27, 2009 | Metrologic Instruments 9520 Voyager
Voyager 9520 10 digit UPC
The last digit should be a parity Digit (used for error checking)
you may be able to clear this using the settings barcodes in the user manual
Mar 31, 2008 | Metrologic Instruments 9520 Voyager
Can't even start Metrologic voyager 9520
The MS9520 with RS232 needs the AC adapter plugged in to operate, the adapter plugs into the serial cable at the plastic "bulge". Cable part number is 53000c-3
Hope this helps, Terry @ TAG Technical INC
Mar 13, 2008 | Metrologic Instruments 9520 Voyager
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
My RS-232 scanner beeps at the bar code but nothing appears on-screen.
The "Beep" just means that the scanner has been presented with a valid barcode. (nothing more) The scanner has probably not been set up correctly as this is a common issue. the settings need to be set correctly for your environment. you should have a code book with some bar codes in (part of the manual) which can set all the options within the scanner, There is an option to recall defaults here is the electronic manual ftp://ftp.metrologic.com/pub/download/productmanuals/00-02544.pdf
Oct 03, 2007 | Metrologic Instruments 9520 Voyager
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Metrologic Instruments 9520 Voyager Logo
577 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
