Question about Lexmark C533DN InkJet Printer
Cant get power on my printer when i switch it on has been ok until today
    Guru:
  • 1,738 Answers
Try unplugging it for about fifteen minutes or so. It could be your buffer or memory is full.
Posted on Dec 09, 2009
Canon np258 cant operate after refill
You may need to reset the ink counter. Try one of the following solutions.
THis is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Mar 27, 2011 | Canon Office Equipment & Supplies
I just bought the hp psc 1200 secondhanded and yesterday it worked. today however, the printer won't switch on. wat must i do now?
I would try to disconnect the power cable and interface cable USB or Parallel from the printer.
Then, after about a minute, connect the power cable first, and see if your printer is powering up.
If not, the problem is more likely in the printer itself.
If the printer powers up OK, then the problem could be in the interface cable or printer driver.
I would also check the PC USB port by connecting to it some flash drive.
Sometimes, it's just a power glitch. By disconnecting the power cable for 1 minute and connecting it back could resolve the problem
Mar 02, 2011 | HP Office Equipment & Supplies
I cant get my printer off chinese how can i get it back on english?
The way was hidden somewhere in the HP solution center:
1. Press the cancel and power buttons at the same time, while the printer is on.
2. Press the blue, green and gray buttons (in this order)
3. Change the menu options with grey button until you get to the "Resets" menu.
4. Press OK. "Country and Language reset" displays.
5. Press and hold OK for approx 2 seconds, then release. The printer will turn off.
6. Start the printer again - it should ask you to select language.
Jan 03, 2011 | HP Office Equipment & Supplies
Machine won't start. Worked fine until today. No power indication when start switch is pressed. Fuse is OK
if you have an electronic control board on this machine it needs to be replaced
Sep 16, 2009 | Washing Machines
Cant print using Canon Pixma MX300
Hi
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
Or try this
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
  1. Switch off the Canon MX300 and disconnect the power cable.
  2. While press and hold the power button, Connect the power cable to electric socket.
  3. While pressing the power button, press the “Cancel/Stop” button (red button).
  4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
  5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
  6. A test page will print.
  7. Open the cover, like you are about to change the cartridges.
  8. Disconnect the power cable again without switch off the printer.
  9. Take out the both cartridges.
  10. Close the cover.
  11. Connect the power cable and turn on the printer.
  12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 08, 2009 | Canon PIXMA MX300 All-in-One Printer
Inksystem failure
1. Get the unit into the “Support Menu” by following the steps below according with the product, see the table below:
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release the “OK” button.
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
Aug 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
CANON COLOR PRINTER PIXMA iP1300
I replaced the cartridge and the problem was solved
Sep 08, 2008 | Office Equipment & Supplies
Overload
Hi
Your printer was pawered ON during the Lightening if yes then follow the steps, Try with the different power card if it having the same problem then most probably your printer fuse blown open the printer and check the fuse if the fuse are OK then please check with the service centres
Boopathy.T
Aug 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark C533DN InkJet Printer Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
