Question about HP Photosmart 2575 All-In-One InkJet Printer
Keep getting the message "carriage jam" when I try to print but there doesn't seem to be one. I have turned the printer on and off and pushed and pulled the ink cartridges and all seems to flow well but I keep getting the same message. Any ideas?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a "CARRIAGE JAM" as the term implies is a condition where the bed/carrier of the printheads and in most cases the ink cartridges could not move normally left to right (or the other way around), it is stuck. In most cases, this is after a paper jam and HP has posted information here.
or the printer thinks it is stuck...
Possible approaches and tries for a fix:
  • open up the cover to gain access to the carriage (bed/carrier);
  • move / slide the bed/carrier left-right left to determine if it can move freely;
  • check for obstruction, blockage, bits of paper, out of position ink cartridge or anything out of the ordinary that could and would prevent the lateral movement;
  • there would be a semi-transparent strip of clear plastic with markings extending from the left to the right behind the printheads and ink cartridge holders. There would be bar code like markings that are closely spaced together. This is the encoder strip. The markings are used by the printer to determine the heads' position. Any dirt, dust or ink smudge(s) on this strip would cause the 'eye' no to see the markings nor through the plastic. Fix is to wipe clean. In some other faults, the entire strip could be out of position or one end disconnected. Any of these would cause the printer to think that the carriage is jammed.
Should none of the above be applicable, then the printer would have to be opened up for a look & see.
Good luck and thank you for asking FixYa. Happy Holidays.
Posted on Dec 17, 2009
Why doesn't my HP OfficeJet 7500A carriage move? It is jammed
Try to turn it off, open cover and move carriage a little bit by hand; don't push too hard. For some time it'll get back to life.
Feb 02, 2013 | HP OfficeJet Office Equipment & Supplies
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
Carriage Jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
May 08, 2010 | HP Officejet Pro 850 InkJet Printer
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Carriage cradle stuck on right side!
Carriage system is broken. Uneconomical to repair. Sorry
Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
Error 0xc18a0106
Push OK, CANCEL, BLACK, & COLOR all at once while turning the printer off, turn it back on. I had to do this 2 times to get it to work and then it went through a long period of maintanence before I could print
Jun 23, 2008 | HP Photosmart 3210 Printer
Printer is not working
Try pushing the print head carriage with a bit of gentle force. It is getting stuck, and hence the error. You may have to open side and top covers to reach this. Note: this is not the cartridges, but another device that moves back and forth on the slider carriage.
May 15, 2008 | Canon Office Equipment & Supplies
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
