Question about Whirlpool Dryers
Whirlpool gold series replaced element clothes still do not dry in one cycle
    Sergeant:
    Champion:
  • 278 Answers
Howdy: A firing ignitor tells the element to heat up. It seems that the ignitor is shutting off too soon. It also could be the timer . Doug
Posted on Dec 09, 2009
Dishes are not dry anymore after cycle?
Hello there:
If` you ahve already checked all of the filters and they are ok than your drying cycle has problems to check these check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat. there:
Normally if you have just started to have this problem and you have checked all of the filters and are sure they are ok than
Jul 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Clothes don't spin dry enough
you mean to say the clothes are tangled with each other tightly right?
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Gold Electric Dryer.
Hope your sitting down. There is not just heating elements in the dryer there are thermal switches that turn heating elements off & on like your house thermostat clicks off & on. Also there are overheating thermal switches to keep the elements from setting the dryer, clothes on fire. More than likely you overheating thermal switch has tripped, from lent in vent or pinched vent tube or normal failure. Some of these switches can be reset, others replaced. If you can not trouble shoot electrical circuits leave it to repairman. Switch $20.00 to $42.00 Labor service call cheaper to buy cheap new dryer. Could be heating element but most use only one with different inputs for heat. If your getting some heat not likely element.
Mar 08, 2009 | Dryers
Whirlpool dishwasher is not fully drying dishes
Are you using jet dry or a similar drying agent? If not you should be. Also check to make sure the heater is getting hot in the dry cycle, just place your hand over the heating element to see if it's generating heat, don't touch it as it will burn you.
Feb 19, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dryer
not element, same element runs Hi and low temp
whirlpool dryers have 2 thermostats,
40degreeC (low)100F
60degreeC (high)140F
the 60degree thermostat has failed
cost is between $15 and $40 depending on how the 'parts guy' feels on that day
the dryer is easy to open, check any of the 'change belt' questions or Joks instruction brief
Oct 26, 2008 | Whirlpool LER4634J Electric Dryer
Dryer quit drying
if fairly new and element back 279816 is pt # for saftey element 279838 i think
Apr 24, 2008 | Whirlpool LER5636P Electric Dryer
Dryer will not dry cloths
make sure that the dryer has the proper voltage going to it and if it does then check the heating element and the safety on the left top of the element housing
Apr 18, 2008 | Whirlpool LGR7646E Dryer
Dishwashers does not dry most dishes even on longest cycle?
make and manufacture would be helpful in trouble shooting for you
Mar 10, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dryers Logo
81 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
