Question about Magellan MAESTRO 3100 98083401 GPS Device
I tired to an update and the my device turned off, now when i turn it back on, it stays locked in the blue magellan screen
    President:
  • 1,111 Answers
Magellan will repair or replace any of there units that were rendered inoperable due to there updates.
follow what i told this guy, he is getting his repaired or replaced free. READ AND FOLLOW CAREFULLY!
(i have changed some things to reflect the 3100, like the update.)
let me say this 1st because this will be the easy way to fix this assuming you tried to either run the update or ran it again after the failure. if thats the case.
im going to assume you tried to update your unit to the 2.18 update that you downloaded off the magellan site,HERE ( if you havent, i suggest you do it before continuing) and in doing so it bricked your unit.
Magellan Will repair or replace any of there gps sytems that were rendered inoperative due to their updates. they will check your account to see if you downloaded the update.
  • register your unit on magellangps.com if you havent already
  • download the update
  • attempt to install update on your computeri tired to an update and the my device turned off, - 2.gif
  • call magellan tell them your unit is not booting up after the update
Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
Telephone: 800 707 9971
hopefully you understand what im saying here.
should you decide to take a different route, let me know and i will help you get it up and running if possible.
bill
Posted on Dec 09, 2009
Magellan explorist XL won't power up past a blue screen
Sounds like you got a bad update, you might be able to download an update from magellan, and put it on your sd card then load it that way to finish the update.
Jul 14, 2013 | GPS
Magellan maestro 3100......will turn on, but then just stays on a warning screen?? Do i need sd card or anything?
make sure its charged good, then turn on your 3100. after it boots up, hold the power button for ten seconds, when it turns off, turn it back on.
that should work, but if it doesnt, hook your usb up to it and your computer and see if the computer can see your 3100. if it can, go HERE and download the 2.18 update and that should fix it.
NOTE: read the directions entirely and do not unplug the unit until the Update wizard instructs you to do so.
either plug it in to the wall charger or make sure the battery is fully charged.
unplugging or losing power while updating will render the unit inoperable!
be patient, this update takes about 30-45 minutes to install..its 1.76GB
if you need further help, let me know by replying to this post.
bill
Sep 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Hi, I have Magellan roadmate 3000t. When I turn it on, it shows Magellan blue screen and stays it forever. I tried to reset many times without success. Can you help me to solve this problem?
if you havent updated it yet, you can go here for the update for your model..just look up your model on the right side and download your update (you must register on magellangps.com to be able to download)
Jul 03, 2009 | Magellan RoadMate 3000T GPS Receiver
Magellan just stays on Magellan blue screen
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Other than replacing the unit, there appears to be no "fix".
Feb 18, 2009 | Magellan Maestro 4250 GPS
There is a RESET button on the bottom of the unit on the left side
Nov 22, 2008 | Magellan Maestro 4040 GPS Receiver
No a practical solution, but at least you will get your device repair, after being on hold for 40 minutes I spoke to a very nice rep, unfortunately evethough she didn't admit it, it seems a software problem with the new 2008/2009 map update, in other words no way to fix it, you need to send it for repair, make sure you tell them to update the device with the new 2008/2009 Maps, if not you will have the same problem later on, Good Luck
Jun 25, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
Magellan Maestro 3100 locks
You can try a hard reset. Hold in the reset button (left side of unit, use a pin or toothpick), while turning on the unit. If you don't get the blue Magellan screen, you'll have to try again. If you get a screen with a blue background and a menu, turn it off and try again.
So far, this has fixed:
1. unit won't go on
2. unit reboots when routing
3. unit turns off after a few seconds
At least, it's fixed it for me. No idea why this happens, but it's pretty damn annoying. Give it a try.
Dec 26, 2007 | Magellan MAESTRO 3100 98083401 GPS Device
Screen Freezes
register your unit on the magellan website and there is a firmware update and it will solve your problem
Dec 18, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan MAESTRO 3100 98083401 GPS Device Logo
162 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
