Question about Sharp AR-168D Black and White Copier
When i make a copy only a single line appears on the sheet ?? Sharp ar 168d
    President:
  • Sharp Master
  • 1,447 Answers
Change Drum clean blade,or clean paper dust.
Posted on Dec 10, 2009
Error code (L1-00) on sharp AR-168D
When[L1-00] appears,the scan head locking switch is locked.Turn off the power,release the scan head locking switch,and turn the power back on.
Nov 03, 2011 | Sharp AR-168D Black and White Copier
When i make copies only a single black line appears on the sheet ??
lift up the doc feeder and look at the **** glass(long rectangular piece of glass) sometimes white out or toner gets stuck on it... or even a staple... clean it with rubbing alcohol and a smooth piece of cloth... try copying again... if it returns and the glass is clear... look right above the **** glass where the plastic sits that guides the paper sometimes ink or whiteout builds up there and you have to clean it... if its tough to get out use your fingernails...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 09, 2009 | Sharp AR-168D Black and White Copier
Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Aug 26, 2009 | Sharp AR-168D Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
Drum replacement
open the right side door.open the front door.unscrew the devoloping unit lock screw. pull the unit out. pull drum unit out fromthe copier.
Feb 16, 2009 | Sharp AR-168D Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Black line
try cleaning the scan glass, there should be a thin scan glass that the paper runs over when you use the feeder that may have white out or some other foreign object on it, try cleaning this using rubbing alcohol and a cloth rag
Feb 25, 2008 | Sharp AR-168D Copier
Sharp AR-168D Black and White Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
