Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do I get the information or photos from the Kingston 2gb Data Traveler on to my computer? I have put the device in the usb port the computer has detected it as hardware but that is all. It does have its own driver so something should show up on the computer so that I can use it.
  • Tony R.
    Tony R. May 11, 2010
    It would be helpful if you could indicate the operating system and computer type. Older Windows operating systems (98SE and 95B, for example) need a driver for every make and model of USB device that one wants to use, while Windows XP and later drivers are "universal" and can handle most USB memory devices, cameras, printers, scanners, etc. without having to install a new driver. With the proper driver, the USB thumb drive should simply show up as a removable drive on your computer and you should be able to drag-and-drop folders and files just as if it were a built-in hard drive.
    Guru:
  • 1,481 Answers
Does Windows (assume u r running Windows) detect the new hardware when you connect it to the USB....
what Windows version r u using.....Vista / Win7 has some issues with respect to some drivers not getting fully loaded while installing the OS.
try the foll;
go to Device Manager/Universal Serial Bus Ctl/+ (expand)USB Root Hub/right click on each root hubs/properties/power management/
Uncheck the box that says"Allow the computer to turn off power....."
the option if checked / ticked will disable the USB hub to shutoff...as such ur USB devices wont function properly.
Go to My computer/open it by double click....
do u c all the drives there....the USB device should show as "Removable drive" press F5 to refresh or use the View/Refresh comand in the menu...
Posted on Dec 10, 2009
    Sergeant:
  • 186 Answers
Hello if your using Windows open My Computer and your device should show up as a drive (E: or F:) if it does right click it and open it. Before unpluging it look for the safely remove hardware icon down by your clock.Click this and choose stop before unpluging.
Kingston dti/2gb usb fd file system is unknown
might be encryoted,, format if you do not need the information
Jan 12, 2014 | Kingston DTI/2GB Data Traveler 2 GB USB...
Not working USB data travelter 4 GB message error is USB device not recognized plz solved this problem and send me best clarification.
Hello and Welcome to FixYa!
The error you quoted can be due to multiple reasons. Following are some main Possibilities, that you should keep in mind.
Make sure, the USB port, you are inserting data traveler in, is in working condition. And you are connecting the device properly.
This could happen due to Software conflict, for this you need to remove all the devices connected to USB ports (other than keyboard, and Mouse) and need to restart the system.. Moreover, you can check for the exact error, in the device manager list...
Try checking the data traveler, on some USB port, on which you are sure, that its working properly.
Check for the possibilities, quoted above and do let me know....
Concerned.
Jun 25, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I recently bought my new kingston data traveler (usb) 2gb then i tried to put a few files when i tried to insert it again it was 8 mb only and cannot be fomatted.
> recently bought
Try it in some other computer. If it still has a problem, take it back to where you bought it, and exercise the warranty to get it replaced.
Dec 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I just bought Kingston 4gb data traveler 101. Do I have to download any software to use it for the first time on my labtop?
no you wont need to download any software but you might need some usb controllers if you ever have any trouble with this device here is a guide
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
hope this helps
Dec 20, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a Kingston Data Traveler 8GB USB Flash Drive which I bought 4weeks ago. Whenever I plug it in one of my usb ports, i get a message which says "USB Device Not Recognized. One of the USB Devices...
The thumb drive might have some fault.
Plug it in other OS mainly windows XP and Linux.
If still same problem persists after tried in Linux, problem is with pen drive.
You can ask for a replacement from the dealer as it has guarantee for 5years.
Nov 30, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a kingston data traveler 2gb DTI. i was copying movie files to my data traveler and it removed the volume label and i am not able to change it back. now I am not able to access any files. it does...
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Feb 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I can't format my 2gb kingston data traveler 2ntfs and it stores only less than 28 mb. i can only use this data traveler on my microsoft office word and excel files but about my audio files, all could be...
I have kingston datatraveler 200 (64gb) and I backum 4gb`s on that usb, but when I want to opet that, its corrupted, damaged and now I cant even format my usb.. help
Dec 18, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
What to do for kingston data traveler pen drive ?
Please note that this pen drive has been discontinued. Hence, there are no publically available drivers. Please log an issue with Kingston using the below address:
http://www.kingston.com/support/Form_Region.asp?pn=DTIU3&Form=ProblemReportDT.asp
Hope this helps.
Oct 26, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
76 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
