Is it ZERO volume on your friend's end or just low volume.
The wind screen feature on Nokia is just a black foam under the mouth piece opening.
Over time,it will collect dust and dirty.
I fixed my Nokia 6265i by just passing a vacuum cleaner hose over the mouth piece opening.
I also use an alcohol cleaning pad (SQUEEZE OUT THE LIQUID FIRST) to wipe the mouth piece area.
If your mic does not pick up your voice then you will need to open the N95 and re-solder or replace the mic.
Pic HERE
I will turn the phone navigation keys down and vacuum them first.
The mouth piece open will be on the lowest portion.
I hope this will work otherwise you have to open the case and change and solder the mic.
many thanks I will Give that a try, Mind you, I am not even sure where the mouthpiece is on the phone, but I will find it!!!!
