Question about Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix dropped
Hi, i dropped my Panasonic Lumix lens down on the floor and now the zoom is stuck at an angle (+ a few scatches on camera). I broiught the camera early august this year, will i be able to get a replacement?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 10, 2009
Testimonial: "Thanks so much on the advice on the dropped Panasonic Lumix camera! I went straight to number 7 and twisted the zoom, worked wonders!! thanks a lot!:)"
    President:
  • 2,761 Answers
Sorry, but manufacturer warranties don't cover damage caused by dropping. Recommend you take it to a local camera shop (NOT a department store) or contact Panasonic customer service via their web site to arrange repairs. Be sure to get a firm price before you commit to any repair though, as the fix may approach the cost of a new camera.
SOURCE:
Panasonic LUMIX 14-42mm GX VARIO PZ lens on GF-1 Body
When using different lenses, a few things should be kept in mind.For some you need an adapter and not every lens ail work as the lenses made for this camera. Sometimes focus or other things needs to be set manually. So even when you can connect a lens to the camera you don't have any guaranty it will work fully automatic and correct. Please read the manual tag came with your camera, about the differences between the four thirds cameras and lenses.
Dec 03, 2013 | Panasonic Lumix DMC-GF1 Digital Camera...
Panasonic LUMIX 14-42mm lens to a gf1 body gets stuck on zoom how to fix
What do you mean by "gets stuck on zoom? Are you getting any type of error message?
Dec 03, 2013 | Panasonic Lumix DMC-LZ2 Digital Camera
Lens won't come out after dropping camera.
Only lightly toasted. The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. There is no safe DIY fix for either condition, but the camera can be repaired by the manufacturer or at a local camera shop. Make sure to get an estimate first -- you may need to decide if the camera is worth the cost of the repair.
Nov 15, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Stuck Lens
It seems that the lens is stuck.
If you can repair it i have the repair manual, if not i can repair this problem, I'm not shure if i allowed to send our repairadress in the Netherlands we replaced a few gears or repair the damage into the lensunit.
Mar 27, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
PANASONIC dmcfz8
try to help the lens go out by pulling it very very lightly...
Jun 30, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic lumix dmc-fx01 won't focus
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
Mar 29, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
DMC-FX8
If the lens is jammed in the out position you can try holding the camera firmly and tapping/hitting it against your hand with the camera on. The lens should then retract. If this doesn't work or if you are afraid of dropping it (do it on your bed, that way it doesn't hit the floor if you _do_ drop it), you can drop it on a wood/firm surface from an inch or so up and it should retract the lens. This solution ONLY WORKS IF THE LENS IS JAMMED.
Sep 30, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Lens stuck
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 22, 2007 | Panasonic Lumix DMC-LC43 Digital Camera
Zoom and shutter not functioning
that is a symptom of being dropped and stuck in a mode.
it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
Jul 28, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
730 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
