Question about Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter
Unit seems to lose power after hitting some minor bump... am resolving the issue by (constantly) having to pick the battery off the unit and setting it back down. wtf??!
    President:
  • 1,627 Answers
If picking up the battery and setting it back down temporairily fixes the problem the you need to remove the cover and make sure the cable are tight and also remove them and check for corrosion.If neither of the above fixes the problem then check any connection that could come unplugged by pulling out the battery,or any that are tie wraped to eiher battery cable.
Posted on Dec 09, 2009
Loses memory
you have the memory lead on the radio wired up to a switched wire, this wire needs constant power, like straight to the battery or to a constant power source in your fusebox.
Dec 10, 2013 | Cars & Trucks
Tip
Laptop Power Drain
This troubleshooting will help resolved minor issues like:
1. No LCD display but unit is actually powered ON
2. Laptop battery not charging
3. Keyboard not responding
4. windows no boot issue
*** here's the Tip: tak out the battery and unplugged the power adapater. press and hold the power button for 30 secs then release after 30secs. put the battery/adapter back in. issue above should be resolved. elese fails, contact your computer's manufacturer.
on Apr 03, 2010 | Computers & Internet
Sony laptop 9a3n keyboard not working
have you tried troubleshooting following steps , that may help resolve minor issues,like
here is answer to these all : take out the battery and unplugged the power adapter. press and hold the power button for 30 secs then release after 30secs. put the battery/adapter back in. issue above should be resolved.
100%
have a good time do feedback.!
Apr 04, 2011 | Computers & Internet
It doesn't work
ufacturer
Mar 14, 2011 | Computers & Internet
Model rv-b99 loses presets and does not power off
whenever I run into a memory issue with a portible unit that uses a battery backup I have found battery corrotion on the battery cointacts! also remove the main power source the batteries the wall plug and let it set for several minutes and hit the power switch a few times then retry everything again
Larry(techman)
May 14, 2010 | JVC RV-B99GY Cassette Boombox
No sound but still has power
Yes, one bad speaker connection can cause the radio to shut off all output in a type of protection mode to protect the rest of the speakers...if not that, if the vehicle is equipped with an amp, make sure the amp turn on wire is well connected.
Oct 23, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
I HAVE A 1998 911 CARRERA WITH THE PORSCHE PCM 1 SYSTEM. THE CAR HAS HAD A PROBLEM WITH THE BATTERY DISCHARGING, WHICH HAS BEEN FOUND TO BE THE BECKER RADIO IN THE PCM NOT SWITCHING OFF CORRECTLY. THE...
All car audio equipment uses a power source configuration that has both a full time battery positive lead, as well as a part time ignition positive lead. These both go to the same single unit. One supplies constant power. The other tells the device the ignition switch position which is either "on", "off", or "on accessory." (They don't really need to know the "start" position. If your unit is drawing power when your car is not in use then simply take the hot lead coming from you unit that goes to the constant power from the battery and hook it up to the same spot your radio ignition lead connects to your cars ignition positive. This is not the ideal configuration since you may lose settings being stored in memory each time the car goes of, or the might be other similar minor issues that arise. Most likely there will be no issues and you will not notice any difference in the operation
Sep 18, 2017 | Car Audio & Video
1987 camaro z28 anti-theft lockout
1st I would check the battery if it had been setting while the go from there
May 07, 2009 | 1987 Chevrolet Camaro
Power outage in the car or at home
It's a #6 Torx screw. I just took mine apart and the DC input jack fell out, four broken solder joints.
Aug 30, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Pride Go Go Elite Traveller Plus HD 4 Wheel Scooter  Logo
52 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
