Everything is connected as per manual - problem is the imported image is in black and white. I've tested the VHS and cable on a TV and they are outputting colour, so the issue is with the MV500i.
Comments:
Jan 28, 2008
- Thanks hazydave
I've been experimenting and have found that you can use the supplied cable ( the one with 2 x audio and 1 x video phono plugs ).
Simply connect the yellow video cable as well as the audio to the VHS output and the other end into the audio/video input on the camera.
I _assume_ you're feeding PAL video into the MV500i... one of the simplest ways to lose color information is to feed an NTSC (or PAL60) source to a standard PAL display.
Another possibility is that you're losing the chroma signal. I believe this camcorder has a composite (CVBS) analog input. If you're tapping off a SCART connector, make sure you use a SCART to composite cable, not SCART to Y/C (luminance/chroma). Are you using the same cabling with the camcorder as with the TV?
Was this helpful?
Yes
No
Popular Solutions for Canon MV500i Mini DV Digital
When attempting to load the cassette it will not load and keeps ejecting the tape. This has happened...
(More)
When attempting to load the cassette it will not load and keeps ejecting the tape. This has happened before and I thought it was something to do with condensation but it will not load at all now.
the i movie recognises the canon mv500i imports for a few seconds then stops recording the canon...
(More)
the i movie recognises the canon mv500i imports for a few seconds then stops recording the canon mv500i continues to play
I have a canon mv500 and want to transfer video to pc. PC has no firewire port so I purchased a...
(More)
I have a canon mv500 and want to transfer video to pc. PC has no firewire port so I purchased a firewire to usb cable. Get a message now that i need to install hardware but can find no driver/software. Please help?
