Question about LG 32LC2D Television
Stop showing picture and it shows this flashing lines and makes a clicking noise and it will take longer than normal to turn on and turn off....
My lg flat screen blanks on and off and has no sound
Posted on Mar 25, 2010
  • 11,361 Answers
You may have power supply problem, look for bad caps first http://en.wikipedia.org/wiki/Capacitor_plague
You can get your parts here: http://www.shopjimmy.com/catalogsearch/result/?q=LG+32LC2D+
Posted on Dec 10, 2009
Phillips 60pl9220d 37
The power supply may be failing.
Nov 22, 2013 | Office Equipment & Supplies
Hi I have a Samsung LE46M86BDX , and its beginning to take longer time beforer showing the picture, normally you can hear a "click" after 2-5 sec. and the picture shows, for a few days ago the "click"...
I had the same problem. http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related We're not alone - its a common problem with Samsung. I watched a few of these and was able to see the bad capacitors, de-soldered and replaced them for under $5.00.
Sep 01, 2010 | Samsung 32 in. LCD Monitor TV
Camera lens comes out but no longer takes a picture. Just clicks.
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 21, 2009 | Canon PowerShot SD880 IS Digital Camera
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Dark red prints with lines throught the picture
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
My camera seems to short out and there are horizontal lines in the pictures.
get new batteries, if recharging your current batteries does not work (to stop it shorting out).
reduce your shutter exposure, by changing to Manual Mode (M), selecting +/-, and then the left button (flash) around the Menu OK button. Mine works fine at 1s shutter speed, but was showing horizontal lines before that ...
Nov 10, 2007 | Samsung Digimax S800 Digital Camera
Harddrive is not recognised by my Mac OSX (10.4.8)
When you reboot and hold down the option key, does the drive show up during that initial process? Is the weird noise more like clicking or more like a high-pitched whirring? If the drive has been damaged on a hardware level (causes too numerous to list... age, power fluctuations, being knocked over or dropped, corrosion, poor workmanship...) and won't show up at all, it is probably now a paperweight. There are a couple of utilities available to troubleshoot disc problems for Macs. The most popular are Disk Warrior and Tech Tool Pro. They can often "see" a disc that Disc Utilities misses, and assist you in copying the data from the drive. This process is important to be cautious with, however, since your drive is making noises it should no longer be considered reliable and the best hope is to retrieve your data and then get a new one or have yours replaced [if it is under warranty].
Aug 12, 2007 | SmartDisk Crossfire Desktop (xf160f) 160...
Canon PowerShot SD550
yes, the flash of your camera is not charging. needs repair.
Nov 03, 2006 | Canon PowerShot SD550 / IXUS 750 Digital...
Televison & Video Logo
457 people viewed this question
Computer Repairing
Computer Repairing
