Question about Jenn-Air JGR8875QDS Gas Kitchen Range
Hello,\r\nI have a Jenn-Air Stove type JGR8875QDS
Hello, I have a Jenn-Air Gas Range type JGR8875QDS which has a failed ignitor. Do you know where it is located and how to get to it? I assume the stove has a flexible gas pipe at rear so I can pull it out from the other kitchen units either side.
Regards
Pete N
  • peter_notter Dec 09, 2009
    It's not the oven ignitor it's the one for the gas burners on the top of the stove.
    Regards
    Pete N
  • Jenn-Air Master
  • 8,220 Answers
What you have to do is remove the racks and door. then remove the bottom of oven then remove the flame spreader and you will see the burner. Uplug the quick connect and remove the burner and ignitor so you can mount it on a nice work surface. take cake not to get contaminents on the silicon carbide ignitor filiment or drop it. Nothing to it.
Here is a movie showing how it works and gives an idea where to look;
Oven Ignitor operation
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 09, 2009
We had a small power outage and my stove says F1 what do i do now?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced, GENE
Sep 04, 2011 | Jenn-Air JGR8875QDS Gas Kitchen Range
Where can i get knobs for my range jgr8875qds
There are many places to order them from. The part number you need is 74009148
I would recommend you get them from Jenn Air directly to make sure they match. There are several other places I will list a couple here.
Jenn-Air 1-800-JENN-AIR (536-6247)
Repairclinic.com
Appliancepartspros.com
partsdirect.com
May 08, 2010 | Jenn-Air JGR8875QDS Gas Kitchen Range
Gas oven doesn't work. Broiler does.
Hello - Most likely failed lower burner ignitor. Tests good if above 4ohms. Part is 40$. Can give replacement instructions if needed. Let me know if this helps. Thanks. -ED
Mar 03, 2010 | Jenn-Air JGR8875QDS Gas Kitchen Range
Oven does not ignite right away
The problem is the igniotr is taking very long to heat up...
Replace the ignitor and you will be okay again.
Here is a tip that I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 01, 2010 | Jenn-Air JGR8875QDS Gas Kitchen Range
Oven broil works but no heat on bake
there are two ignitors the bake ignitir is probably bad, check that first.
Jan 28, 2009 | Jenn-Air JGR8875QDS Gas Kitchen Range
I have a kitchen aid stove gas stove top.had a pro longed power outage(24 hrs) will not ignite auto matically any more must use matches.any suggestions?
check the outlet, perhaps it's its hokked to a GFI outlet somewhere else in the kitchen and the GFI outlet has tripped
Jan 11, 2009 | Jenn-Air JGR8875QDS Gas Kitchen Range
Tried to clean top of jenn air stove
If this is a gas stove, you've shorted out the ignitor circuit.  If it is electric...you may have gotten some of your cleaner into one of the controls.  See what doesn't work and trace from there.
Dec 14, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Electronic touch pad problems
From what your telling me, you have tried all the numbers and only 1,4 and 7 beep when touched. Also, the timer display was set at 0:00 when you started. Also, you followed the manual's instructions first, and looked in the back of your manual in the trouble section, and found no answer.
Did you timer ever work? If not, you should be able to a free replacement of the control panel module from an authorized Jenn-Air repair company. It may be a good idea to contact Jenn-Air first.
The timer shows only hours and minutes when first started. For example 2:05 is two hours and five minutes. It goes into the seconds mode only during the last minute.
Dec 01, 2007 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jenn-Air JGR8875QDS Gas Kitchen Range Logo
122 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
