Question about Indesit WA 115 Front Load Washer
INDESIT WIA 101
HOW DO YOU RE-SET THE MACHINE AS THE PROGRAMME KEEPS COMING ON AND I CANT SWITCH IT OFF.
  • 1 more comment
  • sumatra61 Mar 05, 2008
    Hi I have a problem with resetting this machine if i turn it to the off position all the led's should come on and then go out and after a minute the door lock light should go out.If I pause it and disconnect from the mains open and close the door I still return to the same program it also seems to be the same program all the time?? no matter what I set it too!!
  • tomatoes1 Sep 09, 2008
    led light keeps flashing when turned off and door open
  • Anonymous Nov 05, 2008
    Same.
    Problem Solver:
  • 5 Answers
OK - Try this:-
1. Position the dial on number 0 (off) and then unplug from the wall.
2. After at least 24 hours plug back in - hopefully the thing should have reset.
3. This is really important. Select a wool wash program (No 9) and allow it to complete the entire wash until the door lock light starts flashing to say it's finished.
4. Turn the dial back round to position 0 and all LEDs should go out.
That's it - The control board is reset and all should be well
In order to prevent re-occurance, try to avoid canceling programs mid-cycle. It's also a good idea to switch the dial to number 0 and switch the machine off at the wall when not in use if at all possible.
Please let me know if this works for you :)
Posted on Oct 31, 2008
  • craig fairclough
    craig fairclough Apr 21, 2014
    water wont go into the machine but the wash light comes on here a clink but dosent fill with water an start cycle help plz
    President:
  • 1,294 Answers
Press "end of cycle" for 3 seconds, & tell me what happened.
You will rate me also.
Posted on Jun 05, 2008
Indesit wia 101 stuck on one part of cycle and won't move on
check pump for blockage remove plug for 15mins re try
Apr 19, 2015 | Indesit Washing Machines
I have an indesit wia 101 front loader washing machine. At the moment it will not drain or spin & the red light flashes really quickly
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Indesit W 123 Front Load Washer
Changine a heating element on a washing machine Indesit WIA 101
Sam. The small nut and bolt which protrudes between the element ends should be loosened but not taken off. Press on the bolt, which will relax the compression on the rubber sealing block. This should allow you to extract the element. Once you have done this it will become clear..
Feb 20, 2010 | Washing Machines
Indesit WIA 101 Machine wont start.No power
first check the fuse,if this is ok,you will require a main control board,this will require programing for you model and comercial code
Jul 25, 2009 | Indesit W 123 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Door gasket damaged
Have you sorted your problem out yet?
You can get any spares you need by going on line to:www.hotpoint.co.uk, and followning the links.
Good luck.
Dec 02, 2008 | Indesit W 123 Front Load Washer
Indesit WIA 101
to open do power off after 5 min open the door with power off
Jul 27, 2008 | Indesit W 123 Front Load Washer
Indesit WIA 121 washing machine, front loader. The door lock led is continuessly flashing red even when the programme has stopped and the door is opened. I have to switch off at the main plug. Machine is...
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Apr 21, 2008 | Washing Machines
Indesit WA 115 Front Load Washer Logo
1,328 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
