Question about Siemens WXLS143 Front Load Washer
Remove siemens washing machine motor
I have located the motor in my siemens washing machine, I need to check the brushes.
I have undone the two bolts but the motor does not seem to move.
  • Siemens Master
  • 3,463 Answers
You probably need to lever the motor back, as it is probably held in place on the motor mounts.
Posted on Dec 09, 2009
Motor removal for WF000
undo the bolts and pull it forwards....removing the plug of wires....
cheers
Mar 07, 2015 | Hotpoint Aquarius WF000 Front Load Washer
How to replace brushes on a classic 6 1200
Disconnect the power
disconnect hoses
lay machine on it's left side
remove back cover screw and cover
slip belt off pully
unplug motor wires
undo bolts holding motor
pull motor to rear of machine
revome motor to bench
locate brush housings
undo retaining clip and slide out old brush
fit new brush
replete with other brush
reasonable in reverse of removal
Oct 04, 2014 | Bosch Washing Machines
My brushes on my aquarius wma54 need replacing,where is the motor and how do i change the brushes.what type of motor is it
The motor is located at the bottom rear of the washer.
Remove lower rear panel, unplug lead into motor,, remove earth wire.
Remove 2 bolts holding motor to drum, lever motor away from you to remove.
Brushes are located at the end furthest away from the pulley.
There has been more than 1 type of motor fitted to this model, so until you remove the motor, you will not know which brushes you need.
Nov 09, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Need to replace carbon brushes on Indesit Omega 1200
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Indesit W 123 Front Load Washer
I am trying to locate the brushes in my whirlpool awm 5125 washer i have taken the top off but cant locate them
the brushes are on the motor which is located at the rear of the machine sitting just under the wash unit.
You will need a 10mm spanner to remove the bolts holding the motor on. unclip the wiring to the motor and remove.
the carbon brushes are located on the rear of the motor - one on each side of the commutator,
you will need a philips screw driver to remove the brushes
Jan 15, 2009 | Whirlpool AWM5125/1 Front Load Washer
How do i check if the motor or brushes are working on my washing machine
The motor brushes were worn a visit to the domestic appliance centre to get 2 brushes at 19.99 saved a replacement motor.
all working fine now.
thanks
Dec 30, 2008 | Siemens WFXD5200UC Front Load Washer
Where are the brushes?
easiest way is to remove the motor - just held in by simple bolts. disconnect the electrical plug and socket wiring to the motor of course.
Sep 30, 2008 | Hotpoint WMA48 Front Load Washer
Zanussi FJS1225W won't spin
motor brushes can be replaced in situ but you will find it easier to remove the motor.
take the rear cabinet half off and undo electrical connections to motor. motor is held in by 4 bolts. undo and motor will slip out.
brushes are located towards the end away from the pulley and held in by 2 small bolts. undo, withdraw brushes and see if badly worn
easier way is to check continuity across the brushes with the motor in situ using a multimeter
Aug 31, 2008 | Zanussi FJS1225W Front Load Washer
Need to remove the motor to change the brushes {hotpoint wma 31} have undone 2 bolts and removed wires but cant get the motor off.
i find these are rather stiff fixing. if all bolts are off, prize off gently with a screwdriver or similiar
Aug 07, 2008 | Hotpoint Washing Machines
How can i remove the carbon brushes to check if they need renewed.I have a Hotpoint Aquarious model no WMA34. Much appreciated Chris
you will need to remove the motor, Isolate the supply by unplugging the machine, remove the rear panel, slacken the motor fixing bolts, remove the drum belt, now remove the motor bolts and drop out the motor, un-plug the motor connections.
The brushes are at the rear usually housed in plastic one on each side, disconnect the single wire and carefully remove the housing (2 torx screws), taking care not to break or loose the brush as it is spring loaded,a typical new brush will protrude 30-40mm from the housing a worn brush will be much shorter 8-15mm and just make contact with the motor commutator. replace if necessary, check the comm for wear, refit in the reverse order.
Apr 24, 2008 | Washing Machines
Siemens WXLS143 Front Load Washer Logo
615 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
