Question about Sony Ericsson w580i Cellular Phone
Strange numbers on display screen
On the display screen when the phone is closed or open the numbers F4:2208 is where it should say calls and the numbers F4:2262 is where it should say menu or more. I rejected 3 calls and it started doing this. Also when I open up settings? There is a list of nothing but these types of numbers.
How do you turn on bluetooth on kyocera qualcomm 3g cdma phone?
    • 1 Turn on your Kyocera Qualcomm pdQ by pressing and holding the "Power" button until the welcome screen is displayed. If the keypad is open, press and hold the "Power" icon located on the right hand side of the phone's screen. Repeat the process to turn the phone off.
    • 2 Install the Palm Desktop Organizer software. Connect your phone's cradle to your computer and plug in the power cord. Remove your Kyocera Qualcomm pdQ from its cradle during installation. Exit any Windows programs on your computer. Put the Palm Desktop CD into your computer's CD-ROM drive. The installation screen will appear, click the "Install" button and follow the on-screen instructions.
    • 3 Perform your first information HotSync. Click the "Palm Desktop" icon on your computer's desktop. Click the "Sharing" button in the Windows taskbar to open the HotSync Manager, then click "Local." Turn on your phone and put it in its cradle. Open the Kyocera Qualcomm keypad, tap the "Sharing" button to open the HotSync menu and select "Local Sync." Enter your username on the computer and click "OK." When the sync is complete, a "Process Complete" message will display.
    • 4 Make a call with the keypad closed. Pull up the antenna on your Kyocera Qualcomm pdQ and wait for the signal strength icon to be displayed. Use the numeric keypad to enter the phone number. Press the "Send" button to make the call and the "End" button to hang up.
    • 5 Make a call from the call history on your Kyocera Qualcomm pdQ. Press the right "Smart Key" and use the "Up" and "Down" button to scroll through your call history until the desired number is highlighted. To see more information about the number, press the left "Smart Key." Press the "Send" button to make the call and the "End" button to hang up.
Feb 24, 2012 | Kyocera Cell Phones
My screen on the lg vx5500 cell phone is making strange shapes. When the phone starts up, the bottom half of the screen shows what should be on the top, and the top half is just a white screen. When I...
Your problem is caused by the communication foil between the LCD and the mainboard of the phone. This foil contains a number of circuits that makes data transfer possible. The one or more circuits do not communicate anymore, the phone displays odd images.
Nov 07, 2010 | LG VX5500 Cell Phone
I have a flip phone samsung cricket phone and i can still get calls the front screen works i can dial numbers numbers light up it makes sound but when i open it... The main screen is always white???
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Jul 02, 2010 | Cell Phones
Omnia 2
strange enough. Maybe the Qatari network is only GSM 900 MHzor your phone isn't on the supported list. Try remove the battery for 15 min and then turn on your phone. Also check that network search is set to Automatic so is the band selection.
Oct 21, 2009 | Samsung Omnia Pro B7320 Smartphone
My voyager touch screen broke
There is nothing you can do about this. You will have to open the phone and use it like that. You can still make calls usinf the numbers near the top and then close the phone to talk or have it on speaker in the open form, but the screen will never display anything anymore.
Apr 26, 2009 | LG VOYAGER VX10000 Cellular Phone
Every time I make a phone call My blackberry has a strange symbol
The icon is an indicator for the Enhance Call Audio feature selected on the device. The Enhance Call Audio feature is designed to allow a user to adjust the sound quality over the earpiece of the device (e.g. Boost Bass or Boost Treble)
To improve sound quality for all phone calls, complete the following steps:
  1. In the Phone application, display the menu and select Options.
  2. Click General Options.
  3. Change the Enhance Handset Call Audio or Enhance Headset Call Audio field.
  4. Display the menu and select Save.
To improve sound quality during a phone call, complete the following steps:
1. During a phone call, display the menu and select Enhance Call Audio.
2. Select Boost Bass, Boost Treble or Normal.
To review the different Selectable Phone Equalizers during a phone call, press the L key. The enhancement specific icons are displayed on the active call screen.
Feb 27, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blank Screen
6300 blank display what to do
May 14, 2008 | Cell Phones
Problem when I open the phone, please help!
Okay I work for Sprint as a advanced technical support. Your screen is busted I can tell that when you said it was orange. The LCD is non existent and the colors have mixed. I hope for your sake that you have insurance because it is time to get a new phone. and yes when it is closed the sub screen works fine because it is two separate screens and your main screen is the one busted. It is hard to say if you will be able to get your contacts back because in most cases I have seen that information is lost. So it is time to take it to a Sprint Nextel and Repair center. Hope that helps :)
Oct 13, 2007 | Sanyo SCP-7300 / RL-7300 Cellular Phone
Phone Problem
usually the default lock code is the last four of your phone number. try using that, then hit either ok, or send.
Sep 20, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
No Display for samsang sgh a 800
my Samsung A800 also lost its inner display recently. When I open the phone, the inner display lights up but fails to show any image. Outer display is mostly OK, once it had trouble to "lock" the image and after opening and closing the phone a few times the outer display showed the image with light and dark bits inverted.
Switching phone off and on restores the inner display most of the time, but the image only lasts until I close the phone.
Jun 20, 2007 | Samsung SGH-x427m
Sony Ericsson w580i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
