Question about Hitachi Televison & Video
Hitachi 60" Ultravision TV - bad green tube that is leaking
We have a 12 year old Hitachi 60" Ultravision TV that has a bad green tube that is leaking. I was told it was not worth repairing and that it would be very costlty - any advice?
  • constance newmann Dec 10, 2009
    Dan,
    Thanks so much. I will try a different repair place and see what they say.
  • 4,234 Answers
If this has only started to leak recently, get an estimate from a local servicer for a coolant replacement for that tube. The coolant is corrosive and needs to be cleanedup ASAP from any circuit board that it has touched before there is damage. This is NOT a DIY repair. Expect a repair cost in the $300 range for parts and labor. If the set had a good picture prior to this, it may be worth the repair. This is your call. Do not delay however, as any delay will increase the likelyhood that there will be more damage that needs repair.
Dan
Posted on Dec 09, 2009
Testimonial: "Good answer!"
SOURCE:
On hitachi ultravision when you turn on the power button blinks green and lamp button blinks red. What is wrong?
When was the projection lamp last replaced in this tv?The projection lamp in the tv now is about 1 1/2 or 2 years old and the tv been on and watches like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Sep 04, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
I have a 1999 hitachi ultravision 60" projection tv and the power will turn on but minutes later it shuts itself off. How do I correct this problem?
When was the last time the projection lamp was replaced?The projection lamp on the tv now,has not been replaced like a 1 1/2 or 2 years,tv been on and watches like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Apr 03, 2010 | Hitachi UltraVision 60VF820 TV
Green bulb-or lamp on ultravision hitachi 57uwx20b does not work how much to replace?
On a projection television you will have to replace all three(red,blue,green) projection guns in a matched set, the reason is if you replace just the green gun, your picture will be over saturated with green light making your picture look green,because the new gun will be alot brighter than the red and blue guns.
With that said, repair will cost approx.$400+, I've heard up to$600. Good luck !
Jan 09, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Rear projection HD Hitachi Ultravision always has greenish tint
This is what you're going to do, Turn on the Tv and go to the service manual, if the green tint is still there, you have a defective dmd board, but if it's no there, then you have an issue with your video board
Jul 09, 2009 | Hitachi Televison & Video
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision 60" LCD with red glow in center
I emailed Hitachi and they sent a new light engine to my local electronics store that they do business with. All I had to pay for was the installation which was today. I did not have to pay for the part or shipping. My tv is just like new again and the red glow is gone. I did not realize how bad it had gotten. Do not call the regular customer service because they cannot or do not want to help.
Oct 17, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53" Projection TV (Ultravision)
WoW a 10 year old Hitachi TV. I was authorized for these sets. The problem could be one or a combination of many problems. These sets have the stand up type regulator PCBs that went bad all the time! Also could have a Power regulator IC defect. A sweep power supply problem . The flyback did go bad once in a while on these sets. If the set got a power surge, thers like 5 IC's that pop and 12 Diodes that short along with the display IC. If your not a tech You shouldnt attempt to experiment with the set yourself, so It probably wouldnt pay to fix this set If you have to pay a tech to work on it? It all depense on how good the CRT's Are. If you can get a servicer to diagnoise it at a decent price and check the condition of the tubes, Maybe it would be worth investing some money into this set, as these are or were very very good TV's. The balls in your court now. Good Luck
Aug 05, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
177 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
